Results 1 to 10 of 27
Toyota is my choice
- Aug 2005
- 2,063
January 9th, 2006 01:30 PM #1naghanap nami sa other threads wla po ako nakita.. nag le-leak po yung gear oil ko.. ano po yung dapat kung gawin? ano po dapat eh repair and magkano?
help nman po mga sir.. sana hindi madugo..
ride is corolla xe 96'
January 9th, 2006 01:40 PM #2
usually oil seal or gaskets lang yan. mas maganda ipatingin mo na sa trusted mechanic mo kesa lumala yung leak nya.
January 9th, 2006 01:41 PM #3Originally Posted by finchy18
Toyota is my choice
- Aug 2005
- 2,063
January 9th, 2006 01:43 PM #4uu nga po eh.. mag che-check po kasi ako every morning.. may phobia na me sa leak po sir eh.. cge lng check ko to sa serviteck.
sir okey lng ba gamitin ang kotse kahit may leak?
January 9th, 2006 01:44 PM #5
ganito rin ang problem ko pero di ko sure kung gear oil nga, pano ba malalaman kung gear oil or engine oil ang nag leak?
my ride is kia GTX at un madalas ang problem.... help!!!
Toyota is my choice
- Aug 2005
- 2,063
January 9th, 2006 01:46 PM #6Originally Posted by Teddycom23
Toyota is my choice
- Aug 2005
- 2,063
January 9th, 2006 01:55 PM #8sabi po kasi ng mechanic iba ang amoy sa dalawa.. pra ma sure po dalhin mo nlang sa serviteck pa check nlang po.. libre po basta pa check klang..
January 9th, 2006 02:02 PM #9
first of all determine where the leak is coming from. leak bang yan as in may pawis or may tulo na sa garage? have your engine carwash together with your undercarriage. baka naman sa distributor nanggagaling yan. mahirap din magbaklas ng tranny kaya be sure it's coming from there.
January 9th, 2006 02:11 PM #10Originally Posted by finchy18
nangyari na yan sa car ko xl 96. pinagawa ko sa REMVA cainta. galing don. oil seal sa cv joint area after ginawa then testing namin good na condition. mura lang naman parts.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
