Results 1 to 10 of 11
- Dec 2012
- 7
January 11th, 2013 04:01 PM #1mga sir, tulong naman sa paghanap ng gas pedal ng ford focus 2.0 AT 2005...nasira yung samin..hindi madetect ng computer box nung pinascan namin...nagpunta na ako sa evangelista at caloocan pero wala silang ganun part..sa mismong ford 4weeks pa dumating tapos ang mahal (7,200.php)
baka sakali may nakakaalam sa inyo kung san pa may reliable na mpapagkuhanan ng ford spare parts.
thank you!!!
January 11th, 2013 05:25 PM #2
na try mo na ba pa scan uli sa iba? remember scanners are not created equal. nakailaw check engine and walang power (limp-in)?
- - - Updated - - -
- Dec 2012
- 7
January 11th, 2013 07:25 PM #3yes sir..bale 2 na ung nagscan..same error..hasel lang sobra kasi ndi magagamit ng 4weeks...nakakapagtaka kung bakit ang tagal naman nun...kala ko pagpunta mo sa kasa sabihin mo lang ung part at may available na agad sila
thank you sir sa reply
January 11th, 2013 07:46 PM #4
Uncommon parts are not stocked at the dealerships. Same holds for all brands.
Tried MazFord already?Last edited by niky; January 11th, 2013 at 08:01 PM.
January 12th, 2013 10:40 AM #5
nung pina scan mo ba meron nabasa na dtc (fault code)? or it's a communication problem? kung may nabasa na fault code pwede mo ba i-post
- - - Updated - - -
- Dec 2012
- 7
January 12th, 2013 12:57 PM #6DTC P1215 ung lumabas na code.hindi ko alam sir kung san yung MazFord e.San ba meron nun para pede ko din puntahan..Hindi rin ako makapaniwala na abot ng 4weeks bago dumating yung part
- - - Updated - - -
January 12th, 2013 02:33 PM #7
pedal position sensor c circuit low input. hindi ko ma recall kung nag try na ako maglinis nito..nothing to loose naman
- - - Updated - - -
- Dec 2012
- 7
January 12th, 2013 04:05 PM #8sir pano po ba linisin yun? kasi nung nabuksan namin malinis naman yung loob (yung part na mukang circuit board)
- - - Updated - - -
January 12th, 2013 05:23 PM #9
yes circuit board actually resistor board.contact cleaner ang panglinis. nababasa ba sa scanner ang reading? 3 apps nyan yung dalawa 2 and 3 directly proportional ang basa mga .5v lang ang difference. yung apps 1 inversely proportional ang reading nya compare sa dalawa. a graphing scanner can help you analyze the voltage readings. nacheck na ba sir ang wiring papunta sa pcm and sa throttle actuator?
- - - Updated - - -
January 12th, 2013 07:12 PM #10
Mazford: 02-732-0395, Banawe St., all the way at the south end, near E.Rod.
Clean the connectors first, just in case the problem is there. Safest is Electra Contact Cleaner. Medyo mahal na, pero it's worth the price.
- - - Updated - - -
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
