Results 1 to 4 of 4
    Aug 2003
    i noticed this just recently after parking at Shoppesville. parang galing sa bandang air cleaner. what's strange is that i hadn't made any tweaks under the hood, save for spraying carb cleaner about a month ago.
    feeling ko parang di maayos ung paglinis nung carb; dapat kasi me nakaapak sa gas para di mamatayan di ba? unfortunately mag isa ako nun, kaya't namatayan ng ilang beses. is it possible that the deposits weren't flushed out properly?
    ae92 XL po
    Aug 2005
    ano carb cleaner gamit mo bro? alam mo yun combustion chamber cleaner? pwde ba yun sa carb? anywayz kpag ma smelly nga ng gas di kaya yong carb cleaner nangamoy? xe sakin bro prehas tau carb din.
    Feb 2005
    It might be the carb cleaner that you used. Nag drip sa kung saan and burns pag naiinitan. Try to rinse it out with water or pa-engine wash mo. Just make sure marunong yung mag-eengine wash. Also do it pag di na mainit ang engine mo. Wag mo din papagamitan ng gaas when washing the engine kasi might damage the plastice and electrical parts. Okay na yung foam shampoo na lang ang gamitin sa engine.
    Jun 2005
    hmmm... baka umaapaw ang gas dun sa float bowl mo? nagbara jets? check mo baka may mga tulo ng gas.... normally mapapansin mo naman yan eh. in case mapapansin mo yung sightglass nyan, dapat nasa gitna lang ang gas level ng float bowl...
gas smell coming from under the hood
