Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Napaka-sensitive ng car alarm ng corolla gli 95 ko! Madaanan lng ng kotse sa tabi ay wang-wang agad. Madiinan lang ang body, wang wang agad. Napaka-eskandaloso! Ano kaya ang gagawin ko?
    Jan 2003
    Beneath your console is your car's alarm electronic box, there is a control knob there (potentiometer) protruding with marking "lo" & 'hi" or "+' & "-" dependent on your alarm's brand, adjust it either to "lo" or "-", that is your car alarm's sensitivity. You have to sneak in underneath to find that box where all other wirings coming from your doors, horn are terminating..Gudluck--clone
    wala akong makitang potentiometer adjustment knob, it's just a black box.
    It's a very small screw. Usually adjusted using those precision screwdrivers na pang-cellphone. Hanapin mo lang.
    On some systems it's a separate black box. Pero usually, built in siya sa brain ng alarm.
    Hmm. Maybe i have to remove and see what's inside. Bka naroon ang sensitivity setting screw.
    If it is difficult doing it yourself then have it done by the one who installed your alarm. They can help you adjust it's sensitivity. :D
    Jan 2003
    Guys, tulong naman. Yong sakin, the opposite. Yong alarm ng kotse ko di na tumutunog. 18 mos pa lang after installation. I had it installed when I got the car from Mitsubishi/Diamond Motors. Nagla-lock pa din pero din na tumutunog. Appreciate your feedack...regards.
    FYI, i opened the box and found a DIP switch. I think you have to adjust switches 6 and 7 to vary the sensitivity (there will be a total of 4 sensitivity level settings).
    sarap talaga mag DiY
    Sebastian,
    Kung under warranty pa ang alarm mo ay try bringing it back sa casa where you bought it. They may be able to fix it for free. Try also checking the alarm horn sa engine compartment. Baka nandito ang problem. I recalled from another thread may nabibili daw replacement horn pag ito sira. (correct me if I'm wrong).:D
    Jan 2003
    Bump!
    San ba tong potentiometer ng Corolla 2000 Gli? Skandaloso din yung alarm ko and I want to adjust it. Wala akong nakita sa dash (driver's side), although hindi ko naman binulatlat nang husto. Haven't looked at the passenger side dash too.
    TIA.
    Jan 2004
    Quote Originally Posted by Yoda View Post
    Bump!
    TIA.
    If that is the same as the 1998 GLi's alarm, there is no way to adjust the sensitivity. That particular alarm does not use a vibration sensor but a proximity sensor. You can turn it off so that it only fires if the doors are opened. It's that or may lumapit lang na pusa alarm na kaagad.
    Jul 2006
    Quote Originally Posted by ;38611
    sir sa ilalim ng dashboard sa lower portion ng driver side, meron dyan nire reset na red button? katabi nyan may black na parang box. mga 1 inch by 1 inch sya. ilagay mo sa negative ng konti. hihina yan.
    same din sa akin..kaya pag nasa open parking ako nasa silent mode yung alarm ko, kasi pag me dumaan na maingay (like mga skooter)a-alarm na agad.
    Sep 2006
    Quote Originally Posted by ;38617
    tama si sir roydok, balik mo sa casa. bago pa e.
    chaka check mo rin po yung ground nung alarm horn, baka maluwag.
    di tutunog yun pag ganun
    Quote Originally Posted by the_wildthing View Post
    been wanting to find this out with my Gli 98 also... most of the time, I am forced to manually lock the car instead of using the alarm lock kse sobrang eskandaloso... wala palang choice... tsk tsk tsk
    Aug 2005
    Eto itsura ng blackbox
    Yung potentiometer can be adjusted by a flat precision screwdriver. Turning it anti clockwise decreases sensitivity, clockwise increases. Yung indicator led lamp lits when a vibration is detected. Nilagay ko na lang infront just below my dash to enable me to adjust it whenever I wish.
    Jan 2003
    Thanks, dude! I think it's the same as the 98.
    Do you happen to have instructions on how to turn this off? I can probably live without it.
    Jan 2003
    Anything? Anyone? Beuller?
    Jan 2004
    Sorry bro, it's in my glove box, and my car is in the Philippines, and I am in the US.
    If I remember correctly, you have to put the key in the ON position, then press the Lock button for five seconds until the LED blinks twice.
    But I could be wrong. That might be changing to valet mode. Anyone with a 98-00 Corolla stock alarm manual?
Balat sibuyas na alarm  :-(
