Results 1 to 10 of 364
Threaded View
October 7th, 2004 02:49 PM #11Originally posted by blugsr98
just to share my experience so far with KHAOS...
so far, their claim on the gas savings is really effective. i really do save around 25% on my consumption upon installation.
8-9km/l without khaos to 10.21-13.27km/l with khaos.
under what testing conditions are these numbers from? I could always claim my car does 10-12km/L under normal driving conditions (and it can)... and thats without khaos. My engine mod is a K&N cone filter.
i think the offer they had on the 'money back guarantee' is something we could look into.
...maybe you are the one who should look into it... read on and find out why.
they also guarantee extended lifespan of the engine.
Who and by what principle of their device's function does that "extends" the lifespan of the engine? Some jeepney driver/mechanic or what?
These are some interesting effects of a lean burn in a standard engine:
-High Temperature - this causes higher than normal operating temperatures. This can lead of your engine overheating. This WILL also result in your motor oil to degrade quicker than it normally would. This will lead to MORE oil changes ... not less.
-Pre-Ignition - This occurs when a point within the combustion chamber becomes so hot that it becomes a source of ignition and causes the fuel to ignite before the spark plug fires. This, in turn, may contribute to or cause a detonation problem. Instead of the fuel igniting at the right instant to give the crankshaft a smooth kick in the right direction, the fuel ignites prematurely (early) causing a momentarily backlash as the piston tries to turn the crank in the wrong direction. This can be very damaging because of the stresses it creates. It can also localize heat to such an extent that it can partially melt or burn a hole through the top of a piston!
-Detonation - (also called "spark knock") is an erratic form of combustion that can cause head gasket failure as well as other engine damage. Detonation occurs when excessive heat and pressure in the combustion chamber cause the air/fuel mixture to autoignite. This produces multiple flame fronts within the combustion chamber instead of a single flame kernel. When these multiple flames collide, they do so with explosive force that produces a sudden rise in cylinder pressure accompanied by a sharp metallic pinging or knocking noise. The hammer-like shock waves created by detonation subject the head gasket, piston, rings, spark plug and rod bearings to severe overloading.
in my case, don't realy know much on tech side of the engine so i just based my car performance on the fuel consumption.
maybe its time to get a third party expert opinion? You did say you are NOT knowledgable on the tech side of engines.
... i do consider this as good investment.
again, it is still your choice to try and not to try the product. thanks!
Information sources:
http://www.misterfixit.com/deton.htm
http://home.earthlink.net/~graham1/M...s/LeanBurn.htm
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
