Results 1 to 10 of 11
January 12th, 2008 06:52 PM #1
I drive a Ford Escape 05 automatic. For the past week, the gas pedal is hard and sticky for the first five minutes of the drive. It becomes normal again as I continue my driving. Tried checking the 3M matting on top of the regular mat as it may be interfering with the play of the pedal.
Any DIY tips that you may suggest? I am suspecting lubrication of perhaps the cable. Can this be done only in casas or a regular mechanic from lets say Servitek?
January 12th, 2008 08:57 PM #2
baka ganun talaga yun bro automatic kasi
pero anayin pa din natin ang mga may ari ng ford escape dito
January 12th, 2008 10:20 PM #3
January 12th, 2008 10:30 PM #4
AFAIK isa cause nito eh stretched na gas cable. Mga guru, please correct me if I'm wrong.
Nangyari sa Sentra ko to dati. What I did was I stuck my head under my dash, and checked to see if there was "slack" on my gas cable. Turned out, there was. I found that there is a good 1/6 of a inch of my cable between that plastic thingy (spacer/grommet..dunno what it's called) and the metal. What I did was I just tighted. Worked for a while pero bumalik. It was then I decided to replace. Nung pinalitan ko, okeh na.
Hope this helps.
January 12th, 2008 11:34 PM #5
Checked underneath and i cant see a cable. All i see are levers at the back of the pedal to a lever going up before the wall.
January 13th, 2008 05:21 AM #6
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 13th, 2008 11:44 AM #8
- Nov 2003
- 3,848
January 13th, 2008 12:18 PM #9it's the throttle body. follow the air filter towards the engine and you should find it.
January 13th, 2008 04:34 PM #10
speedyfix and co., thanks for the tip. Sprayed some oil and cleaned it with cloth. Pedal now as soft as before. Yes, it was due to some build-up at the cable. Problem solved, thanks to tsikot!Btw, I just saved P810 from labor with Ford. I asked them how much it will cost me and they said its P810.
One last shot, on the odometer where you see the P,R,N,D,1,2.....
All gears are easily engaged with a square surrounding the gear indicator except for N. It engages in N but the square is hard to appear. Sometimes, I just move the shifter from D to P then back to N or I just move the shifter up and down just for some motion and the square will appear. Any thoughts?
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
