Results 1 to 5 of 5
- Aug 2003
- 9,720
March 18th, 2005 03:28 PM #1is this a common problem with older cars? mine gets left out in the sun kasi, and fuel inexplicably and suddenly drops...
March 18th, 2005 07:52 PM #2
Never experienced that before, but I think you could check for leaks or your gas tank cap is somewhat loose.
March 18th, 2005 08:21 PM #3
delikado yan kapag hindi fully sealed ang gas tank cap mo, kapag meron naninigarilyo sa tabi ng car mo ----- KABOOM!
Signature
March 21st, 2005 07:36 PM #5
How long do you usually leave your car? A day out in the sun shouldn't produce an observable drop in your fuel level. Unless you have a leak in your tank or your fuel line. Get it checked immediately!
Anyways, if your gas tank and cap is fairly secured and your fuel line is intact, one other location where you might want to look at is your carburator.
Then again maybe your fuel gauge is already old and worn out. Check your reading when your starting your car. Then compare it after driving around the block for a minute. There shouldn't be a big difference in the readings.
Hope this helps ... keep us posted p're
