Results 1 to 5 of 5
- Jul 2006
- 28
July 24th, 2006 12:56 AM #1GOODEVENING PO
TANONG KO LANG ANONG ENGINE MERON ANG GALANT 88-89 SS 16VALVE?
UNG GALANT 89-92 SS 16VALVE EFI BA? AT ANO ENGINE NUNG MPI? FOR CLARIFICATION LANG DKO PO ALAM E.. THANKS
July 24th, 2006 12:58 AM #2
Super Saloon was still 8 valve Carb if I recall right
MPI is fuel injected
GTI if fuel injected with double overhead camshaft configuration for more power
- Jul 2006
- 28
July 24th, 2006 01:49 AM #4Ung Una Na Carb 1.8 Ss Lang 16v B Un?
Meron Din Ss Na Efi Ba? Lam Ko Mpi Efi Sohc16 Na Ung Gti Dohc 16 Dinplan Ko Ksi Bumili.. Dko Sure Kung Malakas Sa Gas Or Not Pero Gusto Ko Midsize Sana Pero Lowbudget Ako.. So Far Pinaka Ok Sakin Is Ung Galant Definently Not Ung Gti Mataas Pa Ksi So Limited Lang Tlaga Choices Ko Any Sugg....? Thanks
July 24th, 2006 04:08 PM #5
go for the MPI... mas tipid siya compared sa GTI.
and please stop using all caps.
high idle RPM at engine start
