Quote Originally Posted by marv25 View Post
Is the problem still present on a 2004 Vti M/T? It happened once na while turning at a small intersection and changing gear from 2nd to 1st since there was a hump the RPM dropped for no good reason to about 500RPM, and the battery light was illuminated na, and when the gas pedal was immediately stepped on, the RPM went up and the engine was immediately revved to about 6kRPM, then everything was normal. This only happened once.
i don't think it's a problem on the latter models already... but it wont hurt to check with your dealer. based on what you encountered though it's probably not the TDC sensor as a problematic TDC sensor would see your engine shutting down even if you try to rev it up... if you have some divebombing idle (as what you may have encountered), try to have your throttle body cleaned. It's common for that to happen on EFI cars as the mileage racks up.
