Results 1 to 7 of 7
    Aug 2003
    guys, ano kaya problema kung may grinding sound sa 2nd gear pag nag-shift?
    saan ba maganda magpatingin may kinalaman sa transmission?
    probably synchronizers, tranny gears, or clutch
    Aug 2003
    may kilala ba kayong specialists? saan kaya pinakapraktikal mapatingnan? dito lang ako QC area.
    Nov 2003
    be prepared to leave the car in the shop for a couple of days if it the gears of the tranny. kelangan buksan pa yan and medyo time consuming yun.
    it could simply be the clutch being worn out tho kaya di ka nakakapasok sa gear. in any case kelangan parin ibaba tranny mo.
    Speedy,
    how about the "jerk"? No matter how smooth I release the clutch meron konting jerk eh, is that a sign na of a bad clutch? Normally the jerk comes whenever I'm shifting from 1st to 2nd.
    thanks
    Nov 2003
    not really, it could be just a case of maling adjustment sa play ng clutch. kumbaga, kahit ano release mo, kulang parin kasi nga sa play.
    baka kaya pa daanin sa adjustment yan pero the best thing would be to bring it to the shop so that we can check it out
    Feb 2004
    kung pumapasok sa rest ng gears 2nd gear lang ang hindi syncro o shift fork ang problema sa 2nd gear at kung clutch naman ang problema mo apakan mo ang clutch for couple of seconds and then ilagay mo sa atras pakiramdaman mo kung mag gri grind at mahirap ipasok kung nag grind at mahirap ipasok may problema ka sa clutch. just my O2:speechles
