Results 1 to 16 of 16
    Feb 2004
    peeps,
    nu bang problem sa matigas na manubela, steering wheel ba twag d2? dati nman malambot sya kso lately medyo matigas ng onti, medyo hirap kng iikot?
    nu kya problem n2, puno nman yng steering fluid... lancer glxi ang ride ko.
    tnx,
    butchokuy!
    Oct 2003
    baka s racking pin b yun??? dko c alm tawag e bsta alm ko d2 inaadjust yun manibela kunggus2 mo mtigas o hnd <rack and pinyon ata tawagdun>>
    Could you guys do post correctly and leave the sms shorcuts on your text messages only?
    baka naman they are posting through their cellphones?
    Signature
    baka sa kadalasan pag hawak at himas sa manibela..tumigas..hahaha:D jok jok
    tama si jeff pa check mo nga rack end (tama rin b?) baka may leak..HTH
    Feb 2004
    think yng "rack and pinion" yun yung mahaba na dinudugtungan ng rack end?
    bka nga kc nun minsan nakita nun fren ko na maluwag na yng bearing dun sa "rack end".
    sir, ang palit ba nito pairs(kabilaan)? nun mangyayari kng d agad mapalitan to?
    tnx po,
    butchokuy!
    check the power steering oil seals, bka may damage na..
    Feb 2004
    falken_09,
    san ko makikita yng power steering oil seal?
    butchokuy!
    im not sure kung saan nakalagay yun, try ask a mechanic.. i forgot na kc eh.. :D
    best bet is to have a mechanic check on it para sigurado..
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    correct!!!!
    suggestion,
    ipa bleed mo muna PS mo.
    if this doesn't work, have your tierod and ends checked
    Feb 2004
    artpogi,
    pre, mawalang galang na, newbie kc ako e - what do u mean about "ipa bleed"
    nun minsan nkta ko medyo mluwag na yng tie-rod end - k lng daw yun, tama ba yun?
    Feb 2004
    meron pa bang ps fluid at kung may tumutulo sa ilalim ng pump mo
    Feb 2004
    kilawind,
    puno lagi ng PS fluid to, lagi ko chk yan sa umaga(brake fluid, PS fluid, coolant and oil).
    lng tumutulo sa ilalim ng pump.
    Feb 2004
    maybe yon rack and pinion mo bumigay na
matigas na manubela!
