Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
    Jan 2003
    ot: afaik yung window a/c pag nagyelo may leak. ewan ko lang sa oto kung ganun din.
    so how does the aircon system work in the starex.. i own a 2001 TDCi.. what i want to say is in my starex i have no means of controling the termostat manually...as far as i know when you turn the aircon on the compressor cycles on and off when the set temperature is reached...in the starex the only way to controll the temperature is to turn the heater knob.. which opens and controls the amount of heat coming out of the vents. wat im trying to say that there is always cold air goin through the evaporator which then goes through the heater system and then out the air vents... so for me the only way to control the termostat is by switching it off...... jst my thoughts..
Freezing Freon?
