Results 1 to 3 of 3
    Apr 2006
    Pls. need help.. symptoms of this vehicle is sputtering and losing power (accelerator pedal not responding). It occur when pressing the accelerator pedal for about 1500 rpm or higher. Within 1 min or up I can hear a clicking sound from the engine bay. After that sound the "wait to start light" on instrument cluster illuminates then rpm drops to idle. Once the rpm drops engine will not get any response from the accelerator pedal. I need to release the pedal all the way up to get a response again. What you think the cause of this problem? TIA.
    Apr 2006
    Bakit wala replies just kidding, anyway got it fixed. The problem is broken positive wire rubbing on the body causing of PCM resetting and all the symptoms mentioned on the first thread.
    Nov 2003
    good info! glad it's fixed na.
Ford 1998 E350 diesel
