Results 11 to 17 of 17
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 7th, 2006 07:32 PM #12
Change brake fluid every 2 years or specified odo reading, whichever comes first.
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 8th, 2006 07:24 PM #13you should be able to wait naman without problems. most important to keep fresh of all of the fluids remaining is the atf so prioritize replacing that above everything else.
- Jun 2006
- 2,605
October 8th, 2006 10:17 PM #14Thanks for the inputs.
Couple more questions:
1. The manual says replace the ATF and ATF filter at 83,000 kms. So if I have the ATF replaced before 83,000 kms, do I have to replace the filter as well or just the ATF? In other words, is it ok to change ATF and wait until 83,000 kms before changing the filter. Or is this a bad idea since the dirt and other contaminants will be mixed in since its in the filter.
2. Per manual, automatic transaxle pan removal and replacement 7 liters, complete overhaul 9.5 liters. Does this mean I need to buy 7 liters of ATF when I have it replaced?
Speedyfix, can you pm me an estimate on how much it will cost to replace ATF w/ and w/o filter, brake fluid, power steering fluid, fuel filter etc.. I'm thinking of doing some of it before the next oil change and maybe the rest with the oil change. Stagered service so as not to be hit by a big amount.
Thanks.
- Nov 2003
- 3,848
October 8th, 2006 11:27 PM #15prices are hard to quote... do you want fully synthetic atf or regular? higher quality dot4 fluid or regular dot 3? or will you be providing everything and it's just the labor cost?
pm me nalang the details of what you want me to quote for you or text me nalang
- Mar 2006
- 58
October 11th, 2006 05:20 AM #16Question: is API SL a higher standard than API SH? The manual says kasi pwede API SH above.
- Jun 2006
- 2,605
October 11th, 2006 10:48 AM #17API SL is higher than SH. SH is an old rating that is already obsolete. New oils are normally rated SJ, SL and the newest is SM. All these surpass the requirement for SH. You can safely use it on your car.
VinFast VF 3
