any feedback on this oil? its from england. quite popular here in our province.
im due for an oil change. thanks..![]()
not familiar with that particular oil. look at the rating of the oil nalang so you can be sure it's good quality.
Baka iba nilulubricate niyan. hehehe.![]()
Lubron is a small company founded in 1983. Their products listing does mentioned of oil for hot climates but did not say which/what range.
I would suggest avoiding those light base oil 5w, 10w, 15. They have lots of polymers(additives) that shear and burn forming deposits that can cause problems such as ring sticking. These light base oils are best for England because of their cold weather. If its the one 20-50 range then that would be fine. Remember, as expert says, its the oil that lubricates not the additives.
Best of all, follow manufaturer's recommendation.![]()
just look at the oil ratings first as others have said... It doesn't matter whether it came from England or what not. Just use fully synthetic oil with the appropriate rating to where you live...
