could this be possible? recently hindi maganda yung idle ng auto ko. nacheck ko yung distributor and found na may leak sa loob. this was a problem also before pero nasolve nung pinalitan yung oil seal sa loob ng distributor at nagpalit ng sparkplugs. so thinking it might be the same prob, di ko na pinarepair yung distributor. instead pinalitan ko na ng surplus pero di ako nagpalit ng spark plugs. pero ganun pa rin. rough idle. yung sparkplugs around 1 month old pa lng. ang question, can the faulty distributor damage/affect the sparkplugs?
ah ok. thanks. so i should change my plugs na rin. could it also be the other way around? meaning can damaged plugs affect/damage the distributor? thanks again
yup. nagpalit na ko this morning. so far ok naman. pero dati kasi nung di pa ko nagpalit ng distributor e mga 1-2 weeks lang palya na naman. hopefully ngayon would last a few months. na check ko na rin mga wires and plugs. ok din naman sila. wala ring nakitang oil sa lumang plugs. thanks sa tips!
