Results 1 to 9 of 9
November 16th, 2006 03:48 AM #1
I've been getting this noise from down under at the exhaust pipe. I remember the last time I heard it was like a year ago. Then just last night, non-stop noise...There's this flexi-tube that was offered before...its to minimize the stress on the exhaust pipe and to minimize vibration transfer from the resonator (not sure dito) to the tailpipe...is it any good?
November 16th, 2006 04:55 PM #2
Baka may butas pre. Check mo muna. But if the exhaust is really noisy from the begining, better change to a bigger resonator.
November 16th, 2006 05:36 PM #3
November 19th, 2006 05:08 PM #4
It could be anywhere. Eliminate noise from the gaskets first... but this is easiest to do with the car running on a lift at a good muffler shop. Cheap job, too.
November 22nd, 2006 11:53 AM #5
The premuff/resonator is busted. Hence the hitting metal sound on the t-bars...The rear bracket of the exhaust pipe is also busted. When I get the flexitube, will it not comprise my water fording capability? Where's a good shop to get these jobs done?
November 23rd, 2006 08:08 PM #6
Fremuff is okay, heard CPM is good. If it's a simple job, kaya rin yan ng Nodalo's, but I'm not sure which Nodalo's branches are good, as some are staffed by apprentices who couldn't weld to save their life (I've had exhausts fall off because of this! ).
I always go to a local shop here in Laguna for mine.
As for water fording, no problem. Unless your idle is precariously low, water in the exhaust won't cause it to die in a flood.
November 23rd, 2006 08:49 PM #7
Yung fremuff ba sa may E.Rod? CPM san ba? Thanks niky for the advice. anyone else have their inputs on this?
November 23rd, 2006 09:20 PM #8
CPM, meron ata malapit sa St. Luke's, on Araneta Avenue. Can't help you with any more speifics, di ako taga-metro, eh...
Hybrids and EV
