Results 1 to 15 of 15
    Dec 2009
    Hi fellow tsikoteers! i hope everybody is in good shape upon reading this
    To: Good Mods, hindi lang po ako sure kung nasa tamang section itong thread ko, paki move na lang po. Thank you!
    Kabibili lang po namin ng sasakyan, Ford Escape '05 model. Ok naman po till now yung running ng auto. Bago kami mag close ng deal ng previous owner, sinabi nya na may recommendation yung casa kung sya nagpi-pms na palitin na yung: Fan Module, Tensioner Bearing & Engine Support#2. When i drove test the vehicle ok, for me, ang takbo nya...compare sa 2-escapes-same model & 1-mazda tribute-'06 or '05 (hindi ko na matandaan ).
    Gusto ko lang po kasi iwasan yung possible problem pag pinabayaan ko bumigay yung mga nabanggit ko na parts. (I hope ok lang banggitin yung name ng casa) Nag check ako sa casa, North American Automotive, na nagme-maintaine ng escape, highly recommended kasi nung previous owner, and nakahingi na ko ng estimate quotation.
    NORTH AMERICAN AUTOMOTIVE:
    Fan Module - P9,450 (orig ford brand daw)
    Tensioner Bearing - P9,895 (orig ford brand daw)
    Engine Support#2 - P5,520 (orig ford brand daw - motocraft) <- tama po ba yung pagkakarinig ko sa brand?
    Labor - P2,016
    (Total cost of parts - P24,865)
    Ok na po ba yang price? baka po meron kayo negative or possitive feedback about the mentioned casa, i will really appreciate it very much.
    I've read somewhere here at tsikot na ok sa mazford so nag-check din ako sa kanila. Below are the prices.
    MAZFORD:
    Fan Module - P7,500 (orig ford parts daw)
    Tensioner Bearing - P3,500 (orig parts daw - Isedelco) <- tama po ba yung pagkakarinig ko sa brand?
    Engine Support#2 - P1,800 (orig parts daw - motocraft)
    Labor - P1,500 for Tensioner Bearing & Engine Support#2 pwede pa makatawad pag nandun na, pero hiwalay labor for fan module. Estimate for Fan module labor aroung P1,000++.
    (Total price of parts only - P12,800)
    Ok lang po ako kahit saan as long as ok ang reputasyon and kredibilidad nung casa na gagawa. Ayoko naman makatipid pero sangkatutak na backjob ang mangyayari. Ayoko naman mapamahal tapos sangkatutak din ang backjob.
    Hope you could help me with this. Plano ko po ipasok sa darating na Friday/March16 yung auto.
    Maraming salamat po in advance!
    Sa labas ng casa na lang po kayo magpagawa para makamura kayo. Or kung gusto mo naman bili ka sa labas ng pyesa tapos ipagawa mo sa casa or dalhin mo sa speedyfix.
    Why do you need a new fan module and tensioner bearing? Any problems?
    Isedelco = AC Delco?
    agree with Bin Diesel. buy the parts and have it installed in speedyfix. then replace all the fluids nadin to royal purple.
    Dec 2009
    Hi Sir vinj, many thanks for your reply.
    From the last pms of the vehicle at NAA, they are recommending to have it replaced. What i noticed naman is when i start the engine at #1, may umaandar na kaagad na fan...so i think that's the reason. I also checked it with the casa, yun nga daw po ang dahilan kaya dapat na palitan kasi baka daw madamay pa yung auxiliary fan. About the Tensioner, though im not sure if its related, meron akong naririnig na somelike metal to metal grinding when accelerating coming from stop or slow moving. Pero pag continues moving na, wala naman na akong naririnig. As per the casa, that's also their reason of their recommendation.
    I think you're right with the brand's name. It's AC Delco...sabi kasi ng nakausap ko "isidilcu"
    Ano po sa tingin nyo, sir?
    Thank you po.
    Dec 2009
    * sirs: bin diesel/crazy_boy, maraming salamat po sa reply. Noted po yung advice nyo. Kaso po kasi wala din ako alam or kilala na talyer or mekaniko na magaling. Actually wala akong kilala talaga.
    Re: Speedyfix, sila po ba yung sa san juan? taga cavite po kasi ako, although, im willing to visit their shop.
    Quote Originally Posted by frake View Post
    yes sir. ito yung sa San Juan. they are good in what they are doing. and im sure you'll be very satisfied with their work.
    Speedyfix Manila
    i suggest you also replace the ATF, Coolant, Motor oil, and differential fluid na. if you have the budget, pati brake fluid na.
    hindi mo kasi alam when were those last replaced.
    Aug 2004
    Ford shop brand is really Motocraft, so what you're getting is good enough.
    I swear by Mazford, that's where the Fordclub guys (and everyone else in the city) buy their parts.
    Dec 2009
    Hi Sir niky, thank you very much for your reply. So its okay to bring my Escape to MAZFORD po ba? what i only want is to be sure that the shop who'll handle the replacement have the know how. Thank you po.
    Thank you po.
    Check mo yung maintenance manual kung pang ilang mileage ang recommeded replacement ng tensioner bearing. Actually kapag naka-timing chain ang makina medyo maingay talaga sa umpisa lalo na at pinapaikot pa lang ang langis sa loob ng makina pero nawawala din after a few seconds. Kung may naririnig kang ingay ipacheck mo na nga kasi although timing chain yan pede pa rin magkasira lalo na kapag medyo malaki na ang slack ng chain kasi may problema na ang tensioner. Isipin mo ang chain ng bisikleta diba kapag maluwang ang chain or maalog ang sprocket or plato natatanggal ang chain sa pagkakalagay.
    Thank you po.
    As Niky mentioned, Mazford is tried and tested; we also used to get our Escape and Everest consumables from them.
    On the aux fan, did you try checking other Escapes if the fan opens up the same way?
    On the tensioner, try to get a second opinion as well; it's not "tope" or detonation naman? My experience with busted tensioners before was more of a high pitch screeching sound as a result of the belts sliding. If it's the timing chain tensioner that has to be replaced then the metal sound would also be consistent during start-up of the engine, until the oil circulates. Bottomline, it wont hurt to get a second opinion with another shop before you buy the parts and go ahead with the needed repairs.
    If the ATF hasnt been replaced, time to do so as well; the Escape requires an ATF change every 25,000kms per the owner's manual if i recall correctly.
    Yup. Mazford is okay. Subok na yan sila. ;)
    Pwede mo rin dalhin kay Speedyfix yung mga parts at sakanya mo ipa-kabit. At the same time, replace all fluids na rin kung meron pa hindi napapalitan para isang bagsakan nalang.
    What can you expect, FORD CASA pinuntahan mo. 2x, 3x etc. talaga patong diyan. Well, sa kahit anong CASA naman eh. :hysterical:
Escape '05 2.3l, in need of Parts Replacements Help Please!
