Results 1 to 6 of 6
May 27th, 2007 10:53 AM #1
helo naman po sa problema ng kotse ko, whenever na naka connect ang pvc valve na ito fro, carb to engine cover, palyado na andar, then napapansin ko minsan ok naman pero pag umiinit na pangit na ang andar. nag palit na ako ng valve rubber nito ganoon padin, help naman po, kotse ko nga pala toyota corolla 16v-- salamat po
May 27th, 2007 09:22 PM #2
have you checked the valve itself? might be clogged... do you have a 4AC engine?
Toyota is my choice
- Aug 2005
- 2,063
May 29th, 2007 12:41 AM #3
May 30th, 2007 12:30 AM #4
Yup, have it replaced nalang siguro, or if clogged, possible na baka pedeng makuha sa linis.
Correction, it's PCV (Positive Crankcase Ventilation)...not PVC (not pipe ha!)
Toyota is my choice
- Aug 2005
- 2,063
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
