Results 1 to 6 of 6
    helo naman po sa problema ng kotse ko, whenever na naka connect ang pvc valve na ito fro, carb to engine cover, palyado na andar, then napapansin ko minsan ok naman pero pag umiinit na pangit na ang andar. nag palit na ako ng valve rubber nito ganoon padin, help naman po, kotse ko nga pala toyota corolla 16v-- salamat po
    Nov 2006
    have you checked the valve itself? might be clogged... do you have a 4AC engine?
    Aug 2005
    Quote Originally Posted by botyok View Post
    parang palitan na ata yan pvc valve na yan bro.. sira na yan actually.. same yan sa akin hina ng hatak.. para may singaw
    Yup, have it replaced nalang siguro, or if clogged, possible na baka pedeng makuha sa linis.
    Correction, it's PCV (Positive Crankcase Ventilation)...not PVC (not pipe ha! )
    May 2005
    Quote Originally Posted by rayban7g View Post
    typo error lang (pero nalito ako doon)
    Aug 2005
    hehehe. yeah not the pipe one.. subra mabilis kc mag type. sorry and than x for the correction
PVC Valve
