Results 1 to 10 of 10
- Sep 2007
- 18
October 22nd, 2007 11:33 AM #1Patulong naman po sa pagdiagnose. Ganito kasi yun. Nasa shaw ako tapos pakaliwa ako ng pioneer so nagleft-turn signal ako. Tapos biglang nagopen ang mga locks at umilaw yung battery light. Para bang kapag pinatay mo yung makina tapos naka-ON ka lang. Pero hindi naman namatay ang makina at maayos naman ang takbo. Ayaw lang mamatay nung battery light so tumatabi muna ako para patayin yung makina tapos start uli. Dun lang mawawala yung battery light sa dashboard. Take note na dalawang beses na nangyayari ito. Last week tsaka kanina. Same scenario, same place! Naisip ko baka sa electronics lang ng Corolla 98 ko kasi nangyari lang yun nung nagleft-turn signal ako. Help naman po. Thanks!
- Sep 2007
- 215
October 22nd, 2007 08:09 PM #2grounded yung wires mo ... or your battery clamp is a bit loose...
try tighting it a bit and see what happen ....
if that doesn't help ...check mo yung fuses and mga light bulbs mo
grounded lang yan somewhere get an electrician
October 23rd, 2007 12:14 AM #3
at pa check mo din alarm sys at central locking sys mo baka may loose connection or grounded pwede rin basa ung connection sir
October 23rd, 2007 07:45 AM #4
Kung umiilaw yung battery icon sa dashboard, then most probably may tama na ang alternator (its not properly charging).
Could be a number of reasons, e.g. loose wire or slipping alternator belt, fried or dying diodes or IC, etc.
- Sep 2007
- 18
October 23rd, 2007 11:35 AM #5nangyari lang naman nung nagleft-turn signal ako. di kaya may nagshoshort sa connections nun?
- Apr 2007
- 42
October 23rd, 2007 02:00 PM #6ot po:
sir pag defective IC ba alternator mo palit IC lang kailangan...sa friend ko kasi ito problem nya, hirap magkarga ng battery, low bat na aftrer 3 days. magkano ba gastos pag palit IC? tight budget raw kasi kaya tiyaga sya sa tulak pag low bat na. car is mitsu lancer 89. thanks...
October 23rd, 2007 02:57 PM #7
^^^ Di ako sure sa alternator ng 89 Lancer, pero pag defective ang IC, pwedeng IC lang ang palitan. The problem is, di ko alam kung may shop na nagbebenta ng IC lang. Usually kasi, sa surplusan, buong alternator ang binebenta
- Apr 2007
- 42
October 23rd, 2007 03:17 PM #8ganun nga rin daw po sabi sa kanya ng mga nagbebenta ng parts sa olongapo. palitan na lang raw po alternator kahit surplus lang. akala nya kasi style lang ng mga nagbebenta na palitan para malaki sales nila. talaga raw kasi tipid meal sya ngayon eh...thanks sir.
October 23rd, 2007 11:35 PM #9
Check all signal bulbs of the left side for loose or open connection.
Wires could melt at nagkataon na central locking ang nadamay or the battery pole terminals loosens because of the ground.
October 24th, 2007 12:03 AM #10
pwedeng pa baklas mo ang IC na nasa loob ng alternator and punta ka sa RAON dami oon mabibili IC at ganyan ang ginawa ko noong nagluko ang altrenator noong Mitsu box type 86
Good point on that. But the hybrid one which will give you a ton of savings on fuel maybe worth it...
Mitsubishi Xforce
