bro, ask lang anu prob ng clutch kapag after u mag change ng gear ayaw kagad bumalik,kundi u pa sungkitin? spring lang b prob nun? pls help tnx
I'm sorry but some more questions must be answered before I can give you the correct answer. Your honda year model, Hydraulic clutch or manual type. Do you hear any unusual noises coming from that area of the vehicle? One can speculate to no end about the problem, but it can be a spring off, the clutch master going bad, the slave going bad, or if you just had a clutch assembly installed, the flywheel needed shimmed back to it's original position to keep the linkage length the proper length. Have you had to add fluid to the clutch master cylinder reservoir? Another thing it might be is the release bearing went through the fingers of the pressure plate, as I have saw this before. Let me know and I will get back to you with the answer you need. Good Luck!!!
tnx sa reply po.
sir manual transmission,1994 hatch po nakapag add narin po sa reservoir.
