Results 1 to 5 of 5
November 15th, 2008 08:13 AM #1
bro, ask lang anu prob ng clutch kapag after u mag change ng gear ayaw kagad bumalik,kundi u pa sungkitin? spring lang b prob nun? pls help tnx
November 16th, 2008 04:15 AM #2
I'm sorry but some more questions must be answered before I can give you the correct answer. Your honda year model, Hydraulic clutch or manual type. Do you hear any unusual noises coming from that area of the vehicle? One can speculate to no end about the problem, but it can be a spring off, the clutch master going bad, the slave going bad, or if you just had a clutch assembly installed, the flywheel needed shimmed back to it's original position to keep the linkage length the proper length. Have you had to add fluid to the clutch master cylinder reservoir? Another thing it might be is the release bearing went through the fingers of the pressure plate, as I have saw this before. Let me know and I will get back to you with the answer you need. Good Luck!!!
November 16th, 2008 05:11 AM #3
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 16th, 2008 06:22 PM #5
tnx sa reply po.
sir manual transmission,1994 hatch po nakapag add narin po sa reservoir.
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
