Results 1 to 3 of 3
    Aug 2010
    ung upholstery ng ceiling ng L300FB (sa harap) bumagsak na. nawala na yung dikit.
    Question:
    anong klaseng pandikit ang ginagamit para maibalik ung ceiling? rugby ba?
    meron pang konting dikit naiwan, paano lilinisin ito para kumapit yung bagong pandikit?
    wala bang kalawang? kasi pag meron matatangal lang ulit dapat linisin muna, pwede double sided tape
    Feb 2009
    Quote Originally Posted by trucker111 View Post
    Question:
    if your headliner is made of stretchable fabric, it usually has a urethane foam backing that in time crumbles to flakes or dust and loses its grip on the roof material. if it uses leatherette, it is directly fastened using rubber based adhesive. for diy reinstallation, you need to scrub the area of the old loose insulaltion foam material and the adjoining surfaces with a nylon scrub. then, you can spray 3M brand contact cement (rugby or rubber cement as what it is commonly called in the country)on the inner roof surface. have an assistant or two assist in the installation for alignment of the fabric. careful installation is a must or you miss all the pride installing it right
How to bond collapse ceiling upholstery?
