I saw 4 this week. Just wondering, are there any advantages of having a dual exhaust pipes(not dual tips)?
Hmmm...AFAIK the advantage of dual exhaust pipes is that this set-up would allow the engine to exhaust more freely (compared to having just one exhaust). This lowers the back-pressure that is innate in an exhaust system. Since the exhaust capacity of the engine is improved, you would/might/could notice quite an increase in your engines HP. This provides less smoke for your exhaust. In turn, gaganda ang air-fuel mixture ng sasakyan mo. However, you would/might/could also notice a slight increase sa fuel consumption.
mga tsikot masters, tama po ba paliwanag ko?
tama ka dyan bosing. pero kung isa lang ang headers (meron ba nun?) ng oto mo and 2 exhaust mo e bling factor lang yung isa nun.
Well it depends on the engine, if your gonna put dual exhaust pipes on a 1.6li engine, it might degrade the performance of the engine at the lower to mid rpm range because there is too little back pressure.
baka jaguar yung nakita mong sasakyan?
parang mga new version owner jeeps, magkabilang side sa likod ang exhaust pipe.
dual pipes are appropriate for V-configured engines as what bluebimmer mentioned. in dual exhaust systems, you need to have a "crossover piping" or "H-pipe" to balance out back pressure.
The higher displacement, the better the dual exhaust will work.
AFAIK (warning, mahaba)
Dual Exhausts work for V6 to V12 configuration engines, with V6 benefitting from fully seperated banks, 3 left cylinders into one exhaust, 3 right cylinders into another... many systems will collect them into one for the sake of economy, but they're better off separate.
V8s have varying requirements, due to different firing orders and such, as uneven pulses in the firing order may not benefit from fully separate exhaust, thus a crossover between the separate exhaust pipes may often be needed.
V12s are often treated as twin V6s in tuning the exhaust system, separate exhaust assemblies for each set of 3 cylinders.
Four Cylinder engines don't benefit from dual exhausts, as they: a.) lower the backpressure too much, and b.) cause turbulence downstream... if it's one pipe going into two exhausts, that turbulence saps a lot of power.
well of course dual tip is different from dual exhaust.
diba someone dressed up a mazda6 with dual exhausts? (pero isang set of headers lang yun i'm sure since I-4 lang siya)
is there any aesthetic benefit from dual tips?
Hmm...I would say so. Medyo pogi kasing tingnan eh.Iis there any aesthetic benefit from dual tips?![]()
I saw dual pipes installed in a Nissan Vanette, Lancer GTi 92 model. All i can say then, based on your accounts, is that this is just a waste of money .
If your muffler pipe is too big, you'll lose back pressure along with torque.
sa smoke emmission test nakakabawas ba ito? kasi nahahati sa 2 kaya half lang ang reading, tama ba?
Oo nga, ano... since hindi naman per volume pero total ang testing, di ba? Eh di kailangan dalawa ang machines? :lol:Originally Posted by raine
AFAIK, dual tips aren't a problem, as they are after the muffler and don't have much affect on exhaust flow or backpressure, I think the "dual exhausts" on both the S2000 and the Tiburon still come from one muffler... in fact, this is true on a lot of sports cars... the Corvette has four exhaust tips from two mufflers.
And yes, dual tips look cool... not useful, but just... cool!![]()
...i saw 2 corollas sporting dual exhausts. for a 4 banger car, dual exhausts looks kinda trying too hard to look more powerful than it actually is.
Actually, some Corollas with the 20-valve engine in Japan come standard with dual exhausts, and I guess some of those who swapped to that engine followed the exhaust pattern. But yes, I myself am better off with single.Originally Posted by scarab
dito dami nyan lalo na ang civic na dual exhaust.. puro tunog lang bagal naman
saw a dual-exhaust outlander dati. black siya with chrome rims. i suspect more on bling yung gusto niya with the exhaust. heheh.
