Results 1 to 16 of 16
    May 2004
    Need Help... what would be causing my Rpm to drop to zero when in stop and nanginginig yung engine? ang sometimes the engine just died, i have to step on the accelerator para umangat ulit sia? it already happened to me twice...
    anong car po?
    May 2004
    Lynx 2000...
    Jan 2003
    bka masyado mababa minor mo? imho lang po d ako expert
    Jan 2003
    May 2004
    hindi siguro sa minor kasi nasa daan nako when it happened, it drops pag nkastop ako,
    Jun 2004
    Try mo www.protegetech.org. It is the website for Mazda and Lynx owners. Maybe they have discussions on your RPM problems. Mazda cars are known for these vibrating and dropping rpm problems and chances are they have threads on this.
    check the ignition. could be something loose inside the ignition coil/distributor system. clogged fuel line/filter. loose battery terminals.
    medyo madalas mangyari ngayon niyan sa mazda...
    minsan kahit umaandar... biglang mag drop na lang ang rpm to zero... pero kung nakatapak ka sa gas, mababawi naman niya at tutuloy ang andar...
    paano malaman kung clogged ang fuel lines?
    Feb 2005
    Quote Originally Posted by revoGSX
    anong car po?
    i can relate to this dropping RPM, my unit is 2000 Kia Carnival.... intermittent ang pag-drop especially in the morning on the way to the office....
  11. #11
    Maybe its the MAF sensor... baka madumi.
    Apr 2004
    akin mazda 323 glx 1996... servo kit problem ko...
    Oct 2004
    Nangyayari din s kin yan dati.. tumatakbo tapos pag full stop rpm drop.. nginig.. dead makina... adjust idling lang (screw makikita sa may throtle body) para sa honda...
    Quote Originally Posted by van_wilder
    magkano inabot nyan?
    nawala na yung ganung problem sa akin... ngayon bumalik... buti naka uwi pa nga ako ng bahay kagabi... buset talaga
    try kong mag change spark plugs & oil ngayon ang konting tweaking ng idling screw... pag hindi nakuha palitan na rin ang fuel filter...
    ok na siya... nagpalit lang ako ng spark plugs (hot) and tweak lang yung idling screw.
    Medyo old na yung topic pero same ngyayare sa civic 97 ko,namamatay pa minsan.. Nangyare to after kung magpapalit ng timing belt and tune-up.
Droping RPM
