Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Gud day po..need help my strada 08 driver door e hindi nagoopen kapag sa loob bubuksan..nid ko pa ibaba ung window ko para mabuksan ko gamit ung outer handle.. parang tipong nka child lock ung driver side ko..anu po kya problema nya at mahal po kya parepaire nito? Salamat
    Jun 2010
    check your cars child lock
    Wala po child lock ang driver side ata e
    baka may natanggal sa pagka-kabit.
    baka may nabali.
    you have to have the door siding removed, to see what's wrong. but usually, the problem is easy to see..
    so what's the most difficult part? not seeing what's wrong. because i would have to open the front passenger door and see what's there that isn't on the non-opening driver's door innards..
    tip: inspect the door's bottom panel on the inside. usually, whatever broke or fell, is just lying there.
    Jun 2012
    Pinahiram mo ba? Baka pinilit buksan na engage ang lock. Kung sa yo inabot ang pagkasira, alam mo kung kelan biglang ayaw bumukas.
    Nabubuksan naman sa labas. Most likely, may nabali nga. Mararamdaman mo naman kung nahihila nya yung lock o hindi. I compare mo ang feel pag binubuksan ang passenger side.
    Tanggalin mo yung wall(o sidings ba tawag) ng door para makita mo anong problema. Tinutuklap lang yan. Pero alisin mo muna yung mga screw sa may handle.
    actually, in some cars, there's this dark sticky goo that runs around the inner surface.. be careful. medyo mahirap tanggalin sa damit..
    ^Goo used to stick the sound deadening/ weatherproofing plastic sheet cover.
    Best approach is to open the door panel and inspect mechanism. Wouldnt cost you a cent with DIY but would cost hourly rate with casa people. My bet goes with dislodged connecting rod of lever or some plastic parts broke. Happens when toomuch force is applied with the lever.
    Sir nagpaaus kze ako ng keyless ko gwa ndi nag a unlock pag pinipindot ko..so sabi sakin my iaadjust lang dw dun.aun naaus naman pero after 1hr of driving nung lalabas n ako e automatic naman na pag pinatay ko na ung engine e maguunlock n ung door diba..aun nung pagbukas my tumunog na tas wala ng pwersa pag bubukasan..ayoko ng umulit dun sa pinagpagawaan ko kaya tanong ko sana e kung my nabali n parts e mura lang kya o mahal mga parts sa loob ng door panel? Salamat
    ibalik mo na lang sa gumawa para libre labor, malamang natanggal lang yun pina plastic na clip ng rod
    Oct 2009
    Quote Originally Posted by raycon_24 View Post
    driver side daw
    wala naman naman child lock dun sa driver side
Driver door problem help!
