Results 1 to 10 of 12
- Mar 2014
- 30
April 25th, 2014 10:15 PM #1Gud day po..need help my strada 08 driver door e hindi nagoopen kapag sa loob bubuksan..nid ko pa ibaba ung window ko para mabuksan ko gamit ung outer handle.. parang tipong nka child lock ung driver side ko..anu po kya problema nya at mahal po kya parepaire nito? Salamat
- Jun 2010
- 321
- Mar 2014
- 30
- 54,290
April 26th, 2014 12:27 AM #4baka may natanggal sa pagka-kabit.
baka may nabali.
you have to have the door siding removed, to see what's wrong. but usually, the problem is easy to see..
so what's the most difficult part? not seeing what's wrong. because i would have to open the front passenger door and see what's there that isn't on the non-opening driver's door innards..
tip: inspect the door's bottom panel on the inside. usually, whatever broke or fell, is just lying there.
heh heh.Last edited by dr. d; April 26th, 2014 at 12:49 AM.
April 26th, 2014 12:49 AM #5
Pinahiram mo ba? Baka pinilit buksan na engage ang lock. Kung sa yo inabot ang pagkasira, alam mo kung kelan biglang ayaw bumukas.
Nabubuksan naman sa labas. Most likely, may nabali nga. Mararamdaman mo naman kung nahihila nya yung lock o hindi. I compare mo ang feel pag binubuksan ang passenger side.
Tanggalin mo yung wall(o sidings ba tawag) ng door para makita mo anong problema. Tinutuklap lang yan. Pero alisin mo muna yung mga screw sa may handle.
- 54,290
April 26th, 2014 01:01 AM #6actually, in some cars, there's this dark sticky goo that runs around the inner surface.. be careful. medyo mahirap tanggalin sa damit..
- Nov 2009
- 3,509
April 26th, 2014 01:30 AM #7^Goo used to stick the sound deadening/ weatherproofing plastic sheet cover.
Best approach is to open the door panel and inspect mechanism. Wouldnt cost you a cent with DIY but would cost hourly rate with casa people. My bet goes with dislodged connecting rod of lever or some plastic parts broke. Happens when toomuch force is applied with the lever.
- Mar 2014
- 30
April 26th, 2014 10:47 AM #8Sir nagpaaus kze ako ng keyless ko gwa ndi nag a unlock pag pinipindot ko..so sabi sakin my iaadjust lang dw dun.aun naaus naman pero after 1hr of driving nung lalabas n ako e automatic naman na pag pinatay ko na ung engine e maguunlock n ung door diba..aun nung pagbukas my tumunog na tas wala ng pwersa pag bubukasan..ayoko ng umulit dun sa pinagpagawaan ko kaya tanong ko sana e kung my nabali n parts e mura lang kya o mahal mga parts sa loob ng door panel? Salamat
April 26th, 2014 01:04 PM #9
ibalik mo na lang sa gumawa para libre labor, malamang natanggal lang yun pina plastic na clip ng rod
- Oct 2009
- 2,271
April 27th, 2014 03:37 PM #10
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
