Results 1 to 10 of 10
August 22nd, 2007 10:20 AM #1
1. Ano po ba mga disadvantages kung naka double contact yung mga signal lights?
2. Magkano po ba kung mag pa double contact?
3. Meron po ba kayo mare-recommend na shop na maayos mag double contact?
Thanks in advance!
August 22nd, 2007 10:31 AM #2
malakas kumain ng kuryente pag naka-double contact ang mga signal lights.
papalitan ng sockets na 3 ang linya at double contact bulbs (like those of your tail light)
kung DIY. plus labor sa electrician kung sa labas like banawe.
nauso ito nung 80's pa ewan ko ngayon.Last edited by XTO; August 22nd, 2007 at 10:33 AM. Reason: add'l.
August 22nd, 2007 12:00 PM #3
- May 2006
- 913
August 22nd, 2007 01:23 PM #4are you talking bout your side marker lights?.do you want it to light up with your park lights? if you are its a pretty simple, just conect the negative of the side marker lights wire to the positive of the park lights and it should work..
August 22nd, 2007 01:43 PM #5
Is this what you're looking for?
http://danielsternlighting.com/tech/...rkerflash.html
August 22nd, 2007 01:45 PM #6
August 22nd, 2007 01:58 PM #7
sa reys electrical sa marikina maayos gumawa at mura lang
170php lang singil sakin + 20php tip sa gumawa (chris ang hanapin mo)
magbblink parin yun mas brighter lang, kasi kapag nakadouble contact ka, kasing liwanag ng signal light mo yung yung park light tapos kapag sumignal ka magbblink siya na kasing liwanag ng brake light
- May 2006
- 913
August 22nd, 2007 03:03 PM #8in my starex that is what i did,and it works, but im only talking bout the side marker lights.. when i have the park light on it remains on with the park light.. and when you use your turn signals it will blink alternately with the front signal lights..if you dnt turn your parklights it will work normally.. i had no idea how to do it until i talked to a friend who had it done on his starex,, he said that he got conned into buying double contact side marker lights daw,, so he spent quite a bit on his setup.. but when i looked at the wiring and where it was conected it was simple and i didnt have to replace my side marker lights... just to add im a firm beliver also in keeping to the original and stock colors of the lights on my van.. guess safety is more important to me than not being seen by havning installed or having replaced the original colors of the lights on my van...
August 29th, 2007 04:10 PM #10
di naman siguro magastos sa battery
sana lang may available na double pole socket para sa mga signal lights mo
How about 97 LXi?
Civic horsepower
