Results 21 to 30 of 31
BANNED BANNED BANNED
- 3,790
July 31st, 2007 11:18 AM #21pagpinarefit ninyo yan sa machine shop, sigurado mas mura.
alternative is to get copper metal sheet (available sa autosupply ginagamit as shim)...and cut it to size and use as a shim.
I haven't seen a hilander hinge so hindi rin ako sure kung pede yung shim option.
- May 2004
- 903
August 7th, 2007 04:43 PM #23
- May 2004
- 903
August 7th, 2007 05:47 PM #24850 ata and 450... not sure kay walco nga.... bumili kasi ako ng mga filters e kaya tanong ko nadin... Will that really work?
August 18th, 2007 12:28 PM #25
hello people, newbie here. trying to find exactly this thread. seems we all have the same problem. has anyone actually tried this orig hinge? did it work? pretty big 'play' too on both door hinges on my xtrm....
better get it fixed one time rather than...again and again
suggestions please?...........thanks
- Apr 2007
- 82
August 19th, 2007 05:42 PM #26just thinking bka di yong hinge ang problem bka loose thread na yong kabitan ng hinge either sa car body or sa door.
just my opinion though...
August 19th, 2007 06:46 PM #27
Its easy to check. Open the door and carry it up then down. Observe the bushing area. Kung may significant movement, noise gets louder when door is closed. Parang may kamakatok. To confirm put oil when sound goes away hinges talaga.
August 19th, 2007 07:18 PM #28
*4jgtootsie, junnquinto2006...thanks for the quick reply. positive guys, lifted the door on the other end and there was that play... did check the hinge itself if does move or the screws are loose but no, its the bushing area. have not had any problem as such, on other cars...
FrankDrebin Guest
March 19th, 2008 05:38 PM #30
My friend accidentally reversed his car (Mazda 323) while his driver side door was open. Unfortunately, the door became misaligned and should be given much force in order to latch itself.
Would this only need some bushing replacement or replacement of hinge? Could any of you guys lead me to a shop (Manila-Pasay-Makati area) where we can have it fixed perfectly? Thanks!!!
Traffic!
