Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Jan 1970
    Just bought a 2nd hand 95 Toyota Corolla XL, the body is still great, no squeak good suspension, pero two weeks later my leak na sa engine... I have it checked at the Casa, sabi nila the engine needs to be overhauled dahil umaakyat na ang oil sa carburator at a staggering cost of 65K.... Pero malakas pa naman ang hatak lalo na pag patay ang aircon.....
    Do i really need to have the engine overhauled???? Sabi nung mechanic na nakausap ko papalitan lang daw ang balancer ayos na daw 4K lang ang magagastos ko.... Tapos ano tung twin side????
    Please guys help me on this.... This is my first car pa naman....
    The 2nd problem i have to deal with right now is the engine leak.... Parang galing sa ilalim ng carburator... Sabi nung kaibigan ko O-ring lang daw ang papalitan......
    if you have a second hand car, dont bother to go to casas to check on your car. masyadong mahal sila and your engine might not need an overhaul. anyway, your mechanic could be true bout the balancer. pa service mo na lang sa trusted mechanic mo yung oto mo.
    twin side?! its a performce part or should i say a perf carb. i would not go to details coz bago ka pa lang nag-ooto. enjoy ka muna sa stock.
    leaks! madali lang yan. your trusted mechanic can do that like a walk in the park.
    IMHO lang get a second or third opinion.
    Ano yung nagle-leak sa may carb? langis o fuel? baka naman kailangan lang ng carb kit yan.
    Dun lang ba sa bandang carb may leak or meron pa sa ibang part ng engine?
    May consistent bluish-white ba na usok? Or kumakain ba ng langis oto mo?
    kung merong constant bluish-white na usok or kumakain ng langis oto mo, then dapat na nga i-overhaul yan.
    agree with art. baka minimal repairs lang yan. masyado naman overkill yung casa. imho, 8 years pa lang yung oto so i think masyado pa yatang premature ang overhaul.
    sobra naman yung 65k for engine overhaul. kung leaks lang yan go to your trusted mechanic na lang.
  6. FrankDrebin Guest
    For 65K....
    ...you can buy a much better A1 condition surplus engine.
    ...at me sukli ka pa!
    8)
    Jan 1970
    Thank you guys.... Talagang maasahan kayo.... First car ko pa naman ito... I was really attracted sa itsura kasi wood paneling, mag wheels, fully loaded pa at maliit na wooden ang manibela.... Beauty talaga eye catcher ika nga.8O.... kaya lang yun after two weeks may leak na konting oil......
    Can I still get an accurate reading sa oil level pag nakaandar na yung makina???
    One more thing is it normal for the aircon to discharge water???? kasi tuwing paparking ako may tumulo na tubig....
    Please bear with me guys... am still a neophyte pagdating sa car maintenance....:DThank you guys.... Talagang maasahan kayo.... First car ko pa naman ito... I was really attracted sa itsura kasi wood paneling, mag wheels, fully loaded pa at maliit na wooden ang manibela.... Beauty talaga eye catcher ika nga.8O.... kaya lang yun after two weeks may leak na konting oil......
    Quote Originally Posted by Jolam143
    Can I still get an accurate reading sa oil level pag nakaandar na yung makina??? - mas accurate ang oil reading pag medyo nakaandar na maski 5 minutes ang makina.
    One more thing is it normal for the aircon to discharge water???? kasi tuwing paparking ako may tumulo na tubig.... it is kung konti lang, kung medyo panay at marami na, may diperensya na water pump mo.
    Please bear with me guys... am still a neophyte pagdating sa car maintenance.... its ok. :
    [/b]
    Try bringing your car to another shop... from what area are you? Maybe the other peeps can suggest good/reputable shops near your place.
    On the carb, upgrading it or changing it to a twinside might cause some problems... i'm not so familiar with carbs but the twin carbs may just drown your engine given its small displacement. I'd suggest you have your carb overhauled and cleaned though... sa Kamias/Kamuning maraming carb specialty shops and its not that expensive. They can also tune and adjust your carb to its proper specs there.
    Jan 2003
    Happy,
    Jolam was asking about the aircon discharging water. I don't believe may kinalaman ang water pump dyan.
    Jolam,
    Yes, water discharge from the AC is normal, as long as it came from the evaporator.
    Jan 1970
    Thanks for the advice vinj... I will have my car check this weekend.....
    I'll just update you guys para naman di masayang yung mga advices niyo....
    masyado naman yatang mahal ang 65K para sa overhaul ng 2E engine? besides baka hindi naman talaga dapat i-overhaul yang engine mo. As for the leaks pwedeng gasket replacement lang ang gawin ng matinong mechanic diyan. Tungkol sa carburator mo check mo muna baka gas fuel nga iyon kung ganoon pwedeng O-ring nga or baka may gasket din na dapat palitan sa carb mo. Pero definitely hindi aabot ng 65K magagastos mo dito lahat.
    Jan 1970
    Thank you Sauman.... Hahanap na lang ako ng magaling na mechanic dito dahil duon sa casa hiholdap na yata ako dun ah!!!
    pero.. kung talagang kelangan i overhaul...
    change engine k nln.. halos same din gastos.. imho :mrgreen:
    Jan 1970
    Ewan ko ba dito.... By the way guys location ng opis namin eh medyo mataas... walang puknat na 35 deg. climb na more or less 500+ mtrs... pro nakukuha ko pa rin ng 3rd gear at naka on yung aircon...... pumapatak ako na 40-60km/hr......
    Yun nga lang may oil leak... kaninang umaga ng tingnan ko ang dip stick ng engine oil eh lagpas ng half pa naman.....
    Dec 2010
    same with me, when i started loosing quite a few engine oil and a few blue smoke sa exaust(My Xe is now at 210,000kms), i had my 2e engine checked sa CASA then told me na overhaul na daw. 50k estimate. hindi ako naninawala. i accidentally met ang isang mekaniko na nag hohome service, sabi nya, normal problem ng 2e are just the valve seals. And, totoo nga. when we opened the engine ok pa pala yung piston rings ko. i only spent 5k for the parts and labor. 6 hours lang nya ginawa. look for a trusted mechanic. enjoy driving...
    Mar 2003
    wag niyo na overhaul ang 2E engine ng toyota.. magastos lang yan.. ipon nlang ng konti tpos get a 4age 20V blacktop.. 8)
    Jan 1970
    Buddyclub magkano kaya magastos ko dyan sa 4age 20V blacktop...:roll: Available kaya yan dito sa Mindanao???? At isa pa it is guaranteed ba na maganda ang performance nitong 4tage 20V blacktop????
    Thanks.... :wink:
    dre sa autoparts section ng buyandsell na tabloid meron akong nakita na surplus engine 4AGE 20V 29K. di ko lang alam condition nun, try mo na lang tawagan
    Jan 1970
    Sauman puede bigyan mo ko ng number ng nag babuy and sell na iyan, i will try of giving them a call.... thanks...8)
Does my car really need to be overhauled
