Results 1 to 10 of 40
August 18th, 2005 12:23 AM #1
Pwede ba ito?
You buy the chemical, take off your car's door sidings and spray the inside of the door panel yourself. Then do it with everything else you can reach to.
Is there a chemical available that we can buy so we can do it?
Mahal din kasi sa Ziebart at sa Tuff Kote.
August 22nd, 2005 11:17 PM #3
best way for ur problem buy 3m rustproof (undercoat prin rubberize pag tama ang timpla) brush or spray for better finish prang sa casa ang dting
August 22nd, 2005 11:52 PM #5
joey: undercoat is different from cavity wax, you dont apply undercoat into the inner skin of door/sheetmetal panels. cavity wax is the yellow, hardened rugby like layer beneath the car's sheetmetal.
pitbullz: unless the car has been into a collition, there shouldn't be.
August 23rd, 2005 12:01 AM #6
rustproofing ba ang problema or soundproofing? maganda sugestion m kung sound proofing sir saludo ako
August 23rd, 2005 07:41 PM #7
Rustproof lang po not sound proofing.
Sir theveed where is wurth? Any idea how much is the cavity wax?
Papano po kung meron ng rust formation, can the cavity wax still help?
I really intend to do this.
Thanks po.
August 24th, 2005 04:34 PM #8
Wurth is a brand, OEM manufacturer sila of a lot of stuff, kinda like 3M and Bosch.
Sa Hahn Tools shang sells Wurth stuff, although di ko sure kung meron yung cavity wax. Sure ako meron ang Wurth dahil yung ahente pumunta sa shop dati, kaya lang parang ayaw nila magpaorder hehe, di lagi dumadating tapos kami pa pinapabayad sa shipping.
You have to remove the existing rust first, kung surface rust lang light sanding + turko or equivalent will suffice.
http://www.wurth.com.au/cataloguevie...f=A03_0039.pdf
August 24th, 2005 04:45 PM #9
Oh I think eto current pic ng Wurth
Googled for a minute, meron din ibang brand. Not sure kung meron dito.
But yung libo-libong binabayad nyo sa Ziebart/Tuff Cote eto lang yun.
http://www.bodyshopwarehouse.co.uk/meta/35.htm
http://www.chemicar.com/tekton_cavity.php
http://cms.3m.com/cms/GB/en/2-29/rzcREQ/view.jhtml
Here are a couple of good sites if you plan to DIY. The info is for "pre-aerosol" days, so mas madali na ngayon. Good pointers. HTH
http://www.fordscorpio.co.uk/cavitywax.htm
http://www.morrisminorspares.co.uk/esmworkshop.htm
August 24th, 2005 04:54 PM #10
Originally Posted by theveed
sir theveed after sanding and turko ...
kahit wala na ba na primer paint ?
spray na lang ba agad ng wurth or much better apply na din ng primer?
BTW : Thanks for nice links
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
