Results 1 to 7 of 7
June 20th, 2005 05:17 PM #1
advise sa akin ng mekaniko, pa change ko daw differential oil. narinig nya kasi humming sound ng auto ko kagabi. magkano kaya gastos nito? --'98 corolla xe
June 20th, 2005 06:10 PM #2
baka he meant transmission fluid? automatic ba yan o manual?
FF cars don't have differentials in the conventional sense.
Tsikot Member Rank 3
- Dec 2003
- 546
June 20th, 2005 07:43 PM #3wala differential yung 98 corolla.
siguro what he meant is transmission oil? or gear oil, o ATF sa power steering?
pag kulang o luma na ang ATF sa power steering, umuugong
June 21st, 2005 09:04 AM #4
how bout your wheel bearing grease? na repack na ba yan? also the front axles?
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 21st, 2005 11:52 AM #5di dapat yan umugong unless super konte nalang gear oil mo. kung nagbawas sya then iba na yung problem. make sure muna dun galing yung humming noise.
on the other hand, if the gear oil has never been replaced yet it is about time to do so now.
June 21st, 2005 12:22 PM #6
I just checked the billing from last casa job. May nakalagay tgmt trans. gear oil. This was done sept 2004. Un na ba yun sir speedyfix? Manual car ko guys.
- Nov 2003
- 3,849
June 21st, 2005 08:35 PM #7yup that should be it. kung sa dealer ka nagpagawa malamang tama naman linagay nila na langis. the humming is probably comming from somewhere else.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
