Results 1 to 15 of 15
    Sep 2004
    hey guys! i need your help again. i had my front & left rear engine mounts replaced. after the installation, the dashboard vibrates even more especially when i stop & step on the brake. it also vibrates when i'm turning the steering wheel whether i'm on reverse or drive. my mechanic says it should vibrate because the mounts are still new. is that true? he did not use OEM engine mounts. also, when he adjusts the idle speed to high, the vibration stops but i don't think that's the right way to solve the problem. what can be the problem? any ideas? thanks in advance!
    Jun 2004
    I guess since it is still new it would be firmer. I would have gone OEM though for a part like that.
    Quote Originally Posted by chris_d
    agree...expect at least 2-3 months, sira na ulit yan.
    Jun 2005
    I think it should not vibrate with the new mounts. Before you replaced the mounts, was there vibrations?
    Sep 2004
    before the mounts were replaced, the dashboard only vibrates only when the A/C is on but its not that strong as before.
    Jun 2004
    BTW, what is the vehicle in question?
    Sep 2004
    87 Honda Accord
    May 2005
    try to tune-up your car, masyado cguro mababa ung menor mo kya mlakas ang vibration.
    Jun 2004
    On my Honda Accord 95 I've had a problem with the idling speed with the aircon on lately. I may suggest checking the idle air valve and adjust idling speed if necessary.
    Oct 2003
    naku, papalitan na namin engine supports namin..all of them..baka mmya magvibrate din sa akin...
    Aug 2003
    there's this place in Cubao near SM Centerpoint which produces engine mounts from airplane tire rubber (?) or similar. M7 is the name of the place. They take your old mounts, punch out the broken rubber, and put in their machined rubber inserts. It's analogous to the hard polysterene "racing" engine mounts being sold.
    i have to say though, 2 of my engine mounts are replacements and they're not broken (yet). more than a year na... although if I had known of M7 before I'd have gone for it. ang mahal mahal pa naman yung passenger-side engine mount ko (and walang replacement) kaya sulit talaga yung M7.
    Quote Originally Posted by orly_andico
    sir orly_andico,
    pa pm naman po exact address ng M7 planning to replace all of my engine support.
    car ko volkswagen scirocco gt 80 model madali kasing masira yung nabibile ko sa volks shop at mahal pa.
    maitanong ko lang po kung magkano yung napagawa nyo dito. matibay at maganda maglaro ang polysterene (the same din ba ito ng polyurethane rubber?)
    thanks in advance.
    Sep 2004
    just a follow to this question. do i need to replace all the mounts? i only replaced 2 of them. i think whats causing the vibration is the other old mounts.
    Aug 2003
    scirocco,
    # Engine Support Repair
    M7, Aurora Blvd. near CCP (Central Colleges of the Phil.) to your right going to Cubao.
    7003972 - they also do disk brake rotor refacing (250/rotor)
    I don't know magkano. Nasa low hundreds yata eh. They DON'T use polysterene (yun ang gamit ng mga racer sa US) but instead gulong yata ng truck or airplane eh. Basta whatever it is, matibay naman daw and matigas.
    Stick to OEM, kahit M7 sobrang tigas...
    Check your transmission mount as well.
Dashboard Vibration Problem
