Results 1 to 10 of 15
- Sep 2004
- 15
July 13th, 2005 11:03 AM #1hey guys! i need your help again. i had my front & left rear engine mounts replaced. after the installation, the dashboard vibrates even more especially when i stop & step on the brake. it also vibrates when i'm turning the steering wheel whether i'm on reverse or drive. my mechanic says it should vibrate because the mounts are still new. is that true? he did not use OEM engine mounts. also, when he adjusts the idle speed to high, the vibration stops but i don't think that's the right way to solve the problem. what can be the problem? any ideas? thanks in advance!
- Jun 2004
- 1,311
July 13th, 2005 11:12 AM #2I guess since it is still new it would be firmer. I would have gone OEM though for a part like that.
July 13th, 2005 01:02 PM #3
I think it should not vibrate with the new mounts. Before you replaced the mounts, was there vibrations?
- Jun 2004
- 1,311
- Sep 2004
- 15
July 13th, 2005 01:17 PM #5before the mounts were replaced, the dashboard only vibrates only when the A/C is on but its not that strong as before.
- Sep 2004
- 15
July 13th, 2005 01:51 PM #7Originally Posted by chris_d
July 13th, 2005 01:56 PM #8
try to tune-up your car, masyado cguro mababa ung menor mo kya mlakas ang vibration.
- Jun 2004
- 1,311
July 13th, 2005 02:31 PM #9On my Honda Accord 95 I've had a problem with the idling speed with the aircon on lately. I may suggest checking the idle air valve and adjust idling speed if necessary.
July 13th, 2005 02:35 PM #10
naku, papalitan na namin engine supports namin..all of them..baka mmya magvibrate din sa akin...
normally, i would feel for the e-bike and e-trike users, as "these are probably all they can...
E-bike / E-trike ban details released by MMDA
