Results 1 to 7 of 7
BANNED BANNED BANNED
- Jul 2003
- 2,267
September 12th, 2003 10:40 PM #1mag brus, napansin ko na pag inalis ko yung isang tension wire sa kotse ko habang buhay makina eh walang nangyayari. di ba dapat mejo mag vibrate makina or mamatay makina. pero yung 3 other tension wires pag inalis eh nanginginig yung engine na i think is normal. ano kaya problema??? ok naman spark plug at may kuryente naman na pumapasok??? sabi sa akin baka mababa daw compression. kaso it been only more than a year nung palitan piston at piston ring. isa pa eh bakit isang cylinder lang??? palyado tuloy. ndi kya sa cylinder head??? ae92 engine pala. tnx.
- Mar 2003
- 91
September 13th, 2003 05:46 PM #2hmm.. yup bka nga loose compression ung makina.. =( pa compression test ka para malaman mo if ano condition nung makina..
humina ba takbo??
September 13th, 2003 07:47 PM #3
looks like yung cylinder na yun e talagang palyado na ang high tension wire or spark plug nun. ngayon pag nag-alis ka pa ng isa eh 2 na yung hindi nagfi-fire na cylinders kaya nanginginig na engine mo.
- Jul 2003
- 2,267
September 15th, 2003 02:09 PM #4palitan ko uli yung tension wire. ndi naman mahina yung takbo pero pag naandar from the first gear it either apak gas (mga 1500rpm ata) o kung hinde eh magknock yung makina
- Mar 2003
- 82
Tsikot Member Rank 4
- 2,716
September 16th, 2003 01:48 AM #6possible fuel injector problem din ... baka barado or stuck-up na
btw, curiousity lang, have you compared the spark plug from defective cylinder to the other plugs? just wondering kung ano itsura ng spark plug
- Jul 2003
- 2,267
September 16th, 2003 06:23 PM #7actually pinagpalit ko yung mga spark plug pero yung cylinder pa rin na yun ang may problema so i assumed na ndi spark plug ang problema. pinalitan ko rin yung tension wire pero ganun pa rin. so loose compression ba yun??? ang pinatataka ko lang kasi eh bakit yung isang cylinder lang considering na sabaysabay naman pinalitan piston at piston ring more than a year ago [pa lang. suspetsa ko kasi baka yung cylinder head ang problema. yun bang valves sa cylinder na yun kasi mejo may tunog din eh. hindi lang ako sure kaya nagtatanong ako ng expert opinion. : )
