Good day. I was replacing the bulbs because bulb was busted. After I remove the rubber cover at the back of the headlight assembly, bigla na lang nasama yun lock ng bulb buti nasalo ko kasama yun bulb. Ask ko Lang kung maikakabit ko ulit yun clip/lock? If, yes I should remove the headlight assembly for easy access? Location ng headlight nasa left side malapit sa battery. Please help. Thanks I appreciate your comments and suggustions.
