Results 1 to 10 of 12
May 4th, 2005 11:00 PM #1
100,000kms na ang Corolla ko. 2E engine 1.3. Medyo bumubuga na sa oil filler tapos may mga droplets ng oil na tumatalsik kapag bukas ang takip ng oil filler. Pero hindi pa malakas kumain ng engine oil.
Tatagal pa ba itong makina ko?
Magkano kaya ang overhaul?
May 4th, 2005 11:04 PM #2
Kung di naman umuusok ng blue/white at hindi naman kumakain ng langis, ok pa yan for the meantime.
May 5th, 2005 12:37 AM #3
diba normal lang sa engine yun? pag binuksan mo oil cap habang umaandar makina talagang may tatalsik dun
May 5th, 2005 12:45 AM #4
Yes, basta hindi ka pa naliligo sa langis ok pa naman iyan.
May 5th, 2005 09:43 AM #5
If you're worried about compression (as some people say na "loose compression na yan" pag may tumatalsik na oil), then a compression test will help... but other then that, it's normal for oil droplets to splatter about.
May 5th, 2005 10:03 AM #6Originally Posted by OTEP
herherherher....natawa ako dito....
tama si doc....kapag naliligo ka na ng langis (nkupo, ang init nyan...) eh overhaul or palit engine/car na yan....
May 5th, 2005 01:28 PM #7
Thanks for the info!
It seems I can hold on to this car for a bit longer...
How long do 2E engines typically last?
Tsikot Member Rank 3
- Dec 2003
- 546
May 5th, 2005 01:56 PM #8gas engineas 250k km ang lifespan nito.
diesel heheh 1 million km.
pag oil filter lumalabas, sure ka na nahigpitan maayos yung oil filter? baka naman hindi mahigpit
May 5th, 2005 05:23 PM #10
Hindi po sa oil filter bumubuga, sa oil filler hole sa taas ng valve cover :D
Nagpalit na ako ng timing belt 95k pa lang...
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
