Results 1 to 9 of 9
    is it ok for the water level inside the coolant reservoir to change? when the engine warms up, hot water enters the reservoir. when the fans kick in, the water goes down. when the car is not in use, the water level is low then starts to rise again as the engine warms up. i observed that this follows a regular cycle. there is no leak and the temp is at the middle all the time. is this normal or not?
    Jan 2008
    it is normal that the level goes up when the engine is hot, when the pressure cap opens to release radiator pressure to the coolant reservoir and then taking in fresh water to cool the radiator. as you have noticed the max level indicator of the reservoir is placed only 3/4 of the full reservoir volume, you should maintain this level, the remaining space of the reservoir is for the steam that will be released by the radiator going out thru the reservoir release tube
    thank you sir! now i have peace of mind. thought something was wrong with the head gasket or water pump.
    Nov 2003
    that's normal lang. basta it stays full.
    tanong ko na rin mga ser, pano po kung nag overflow yung reservoir mo tapos walang ng laman yung radiator at ayaw bumalik yung tubig.. could this be a bad rad cap? or a headgasket problem? tnx
    Aug 2003
    could be hindi pressurized yun return hose mo.. may air leak somewhere.
    kasi since the cap was able to open up and draws the water to the reservoir naman in the first place.. so yun return lang may problema.
    its like sipping a straw with holes on the side... you cant get liquid back up.
coolant reservoir level goes up and down
