Results 1 to 7 of 7
- Aug 2006
- 152
June 20th, 2007 06:34 PM #1Mga bossing, pinagawa ko kahapon yung aircon ng corolla ko, ngayon ko lang napansin na yung temperature gauge ko is reading below the normal temp (1/4). Kahit na almost 3 hours ko na sya dinadrive. And isa ko pa napansin is when I turn the key to ON (naka-off yung engine), e umaandar na agad yung fan ng radiator, kasi dati hindi naman ganun! Do you think ito yung cause ng drop ng temperature reading ko? Ano kaya ang possible na nagalaw nila dito? Bago ko sana ibalik I want to get your comments! TIA!
Tsikot Member Rank 4
- Jun 2006
- 2,605
- Aug 2006
- 152
June 20th, 2007 11:19 PM #3
June 20th, 2007 11:57 PM #4
this is a bad practice by some (not all) auto airconditioning mechanics/technicians to bypass the fan switch with the hope of maintaining a cooler engine temp when using the a/c. have them (or another shop) check your a/c system and the engine for overheating brought about by overworked compressor, faulty fan rheostat etc.
June 21st, 2007 08:27 AM #5
either naka rekta yung fan or tinanggal yung pagkakakabit sa thermoswitch. mabubugbog fan mo, constantly running
- Jun 2006
- 2,605
- Aug 2006
- 152
June 21st, 2007 02:02 PM #7I will return it on saturday and alam ko na kung ano ang ipo-point out ko sa kanila! Thank you po mga sir!
Thread was made nung 2018 pa po sir.
