Results 1 to 8 of 8
December 17th, 2003 04:16 PM #1
pag sa umaga or pag nai-park ko ng matagal. madali syang mag-start kaso kailangan ko mag-rev ng rev para di mamatay. pag binitawan ko gas pedal namamatay. kung baga kailangan pag-initin muna. dami ko nang napagdalhan na shop pero walang makaayos eh. kahit suki kong mekaniko di nya naayos. napa-tune up ko na din. ganun pa din. ano kayang problema? it's not a big deal naman kaso lang pag iniisip ko medyo aksaya sa gas tsaka di ako makaalis kagad pag nagmamadali. i'm driving a corolla ae92 nga pala. thanks.
- Aug 2003
- 125
December 19th, 2003 10:26 AM #5had that problem before. mahina din ba hatak ng oto mo? if that's so, spark plugs lang yan. palinis mo lang o papalitan mo ng bago. kung ok naman spark plugs mo, palinis air filter at carburetor. adjusting the idling and air/fuel mix also helps.
- 71
December 19th, 2003 12:32 PM #6i think it's not as simple as a dirty spark plug, air filter, or sometimes, even carburators... i also had that problem before, and my friend also... i don't know what the mechanic did, but at that time, i had a top overhaul because it is already needed. when i got my car back, the problem was already gone.
not that i'm saying that the engine needs a top overhaul. what i'm just trying to point out is that sometimes, tune-up can't fix the problem... as what was already mentioned earlier.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 19th, 2003 12:56 PM #7it could be a case of faulty body grounds. or it could be that you need a new carb. bring it to a shop that can diagnose it properly
December 23rd, 2003 01:16 PM #8
your fuel filter may need replacement...
nag replace ka ba ng air filter nung last tune up, baka kelangan na din...
