Results 1 to 10 of 10
- 144
May 27th, 2003 05:38 PM #1ayaw mag activate yung lock pag nag arm ako ng alarm tutunog lang pero hindi na lolock. pag sa loob hindi din nag aactivate yung master lock sa driver side. ano kaya ang dapat check at gawin?
May 27th, 2003 06:49 PM #2
Bring it back to your original installer have it diagnosed and fixed by them. Goodluck.
May 27th, 2003 06:52 PM #3
most probabaly nabasa / grounded yung actuator sa driver (master) side, if you can DIY uninstall it then patuyo in mo pag tuyo na kabit mo na lang.
kung under warranty pa dalhin mo sa gumawa.
- 38
May 28th, 2003 08:44 AM #5Most probably yung actuator ng master (driver side) yung me problema, pwede DIY yan. Syempre kung me warranty pa balik mo na
HTH
- 144
May 28th, 2003 10:05 AM #6eto yung mga na check ko:
1. yung bolt na naka screw sa master lock sa driver side ok namana t hindi lumuwag
2. Yung mga fuse okay lahat.
2nd hand na yung kotse ng mabili ko, ala ng warantya t di ko lama kung san pinkabit.
yung cobra alarm ko yung dalawang pindutan baka meron din may manual ng ganung model pede pa xerox ko para mapg aralan yung wiring.
yung master lock hindi na nag respond hindi na tumutunog para mag lock at mag unlock ng mag pinto pag na arm yung alarm so malamang yung actuator?
madali lang ba magbaklas nun?
salamat po.
May 28th, 2003 11:04 AM #7
ganon din ata yung alarm ko eh... black remote with 2 gray buttons ba? yan ba yung may remote start?
- 3,754
May 28th, 2003 11:16 AM #8For sure actuator yan.. Baka nag stuck lang yon kung tumutunog ibig sabihin may command sya kaya lang ayaw gumana mechanism nya. yung actuator ang tingnan mo, ganyan din sakin dati inayos ko lang yung sa master lock OK na check ko baka hindi maka galaw yung actuator sa master, baka masyadong mahigpit
- Jan 2003
- 16
May 28th, 2003 01:03 PM #9Originally Posted by NightRock
1. 12Vdc. 3 leads/wires motor actuator
2. 12Vdc, 5 leads/wires, motor actuator
Same price lang yan, so if I were you get the 5 leads, coz you can use it as spare/reserve in case may masira uling ibang existing actuators mo. Price range is Php250 to 300.00 ea. lang. Ikaw na lang DIY just observe proper wire colors ebfore & after installation, then seal it with PVC electrical tape para di na siya mabasa at magloko uli. HOPE THIS HELPS.
Clone :D
- Nov 2002
- 65
June 3rd, 2003 08:05 PM #10pansin ko rin yan sa car ko...grounded yata yung sa akin...nagsimula mag loko yung lock ko ngayong nag-uulan eh..kainis
Xiaomi E-Car
