Results 1 to 7 of 7
    Apr 2011
    Mga sirs, help lang, kasi wala ko makita na tagas sa clutch master ko.
    mabilis maubos yung clutch fluid ko, like from north caloocan to pasig and back, totally ubos from being full.
    lalo na pag traffic, pag madalas ang diin at bomba ng clutch, nararamdaman kong palambot ng palambot at palalim ng palalim yung diin ko ng clutch.
    leak na ba to? wala ko makita eh.
    and onga pala, minsan may grinding sound akong naririnig sa ilalim kapag dahan-dahang inaarangkada from 1st or 2nd gear.
    Apr 2014
    chech mo secondary master nasa ilalim malapit sa transmission. am sure andun ang leaking nya. update lng din.
    agree with maverick.
    clutch fluid does not evaporate with ordinary use.
    and if you do not see any leak on the exposed parts, your leak may be the slave cylinder beside the trans housing. it may be leaking into the trans, hence your inability to see the leak.. or, it may be leaking on the outside of the trans, but because the area is "dirty", you may not notice the wetness..
    happy hunting.
    Nov 2007
    Agree with maverick74 and dr.d, judging from your avatar which is an adventure, check your secondary clutch master located near the transmission, most likely you need to replace the repair kit inside. Happened to me before on our L300 diesel FB.
    Oct 2009
    Quote Originally Posted by ans_lim168 View Post
    kung may tama na ung secondary master .
    at parang may kinain na ng anay.
    mas maganda palitan na ng buo..asembly
    para salpak nalang kaunti lang difference nun.
    Apr 2011
    Salamat po sa mga response. additional info lang about my 98 mitsu advie clutch problem.
    pag nasa garahe, hindi naman nauubos yung clutch fluid.
    kapag matagal nakadiin sa clutch (trafik or mabagal ang takbo.), parang nawawalan ng pressure yung clutch pedal, bitawan lang ng ilang segundo, ok nanaman.
    Next sweldo ko na to ipaayos. heheh
    Magkano po kaya labor neto sa clutch? thanks!
Clutch fluid mabilis maubos.
