Results 1 to 5 of 5
- 26
June 10th, 2003 07:31 PM #1Hi, how does one clean clogged wiper washers? The water spouts are erratic sometimes comes in spurts. Kung kaya DIY, ayos kundi pa service nalang.
If you can point me out to one who can service them, Ill be very appreciative
Thanks
Mac
- 26
June 10th, 2003 07:38 PM #2By the way i tried the karayom approach already. The left spouts is still erratic, the right one parang low batt.
Mac
Sorry for the multiple posts, this has been covered earlier na pala
June 10th, 2003 07:40 PM #3
alam ko natatanggal yung housing nyan eh... from there pwede mo linisin.. dunno how to remove it nga lang :roll:
- Apr 2003
- 526
June 10th, 2003 09:05 PM #4i guess pwede nga palitan yung housing kasi pwede ka magpakabit nung blue wiper washers, hehe. I think you just pop/pull them up, not sure din.
Once you have it out, warm water? para maloosen yung dust, soap, etc na nagbuo na.
Baka kaya na yan ng mga tambay na banawe boys
June 11th, 2003 12:30 AM #5
Nangyari na din ito sa Strada ko minsan at walang lumabas. What I did:
1. Check kung gumagana o tumutunog ang pump. If wala then check for fuse burn-out or replace the pump.
2. Karayom technique sa opening ng washers to dislodge precipitates.
3. Pisil technique on all rubber hoses from reservoir to washer to dislodge precipitates.
4. Disassemble plastic connectors in between rubber hoses and use karayom technique to again dislodge precipitates.
5. Drain reservoir of tap/mineral water and use distilled/rainwater as washer fluid to prevent this. Mahal lang nga distilled water.
:D
