Results 1 to 2 of 2
December 28th, 2006 07:42 AM #1
i have a problem, may leak yun sa engine ko. yung takip ko yung space between (engine gasket po ba tawag dun?)
last problem, bkit auto ko pag naka full load ako. like CD, A/C tas yung headlyt ko ginagwa ko dim-bright-dim, bumabagsak or namamtay engine ko, parang kapos sa kuryente. pero pag once restart ko ulet.. ok na sya, anu kaya problema dun
please help.
thanks
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
