Results 1 to 15 of 15
    Dec 2010
    Hello There!!
    I am new to the forum and would like to get assistance on my concern. I am currently purchasing a car from a direct seller and is in the process of securing documents for this. While receiving the original OR / CR from the seller to execute the transfer of ownership, I noticed that there was a slight discrepancy on the chassis number vs. the stencil copy of the vehicle. Can i get advice on how to correct this?
    Quote Originally Posted by never424 View Post
    Hello There!!
    You may seek advice in any LTO office. You may also ask the seller why this is so. If the seller cannot provide a decent explanation, do not purchase the car.
    ask the seller to make necessary correction from the LTO before you purchase the car.. most likely its a mere clerical error and can be corrected easily...
    Quote Originally Posted by phezthie View Post
    might be a hot car imo. to the TS confirm first before purchasing, baka ma sayang lang pera mo.
    Kung may problema sa Numero ng chassis huwag mo na lang bilin marami naman diyan at sakit ng ulo lang iyan.
    It happened to one of our cars before that it was off by 1 digit. Hindi maayos yung pagka-stencil kaya it appeared like a 0 instead of a 9. From what I remember di naman nahirapan to have it changed (although ang alam ko is may kakilala kame sa LTO during that time).
    To TS: Is the "slight difference" same as what we experienced?
    Dec 2010
    Thanks Guys for all the answers.... I already checked it with the seller. It seems clerical error nga lang... na paayos ko na sya... sa records ng LTO. Thanks ulit...
    Sep 2024
    Hi how to process po may I know. We brought car po also kaso instead na 8 ung naka lagay sa CR B po yung naka record . i think error din po ng LTO. by the way second hand yung nabili namin
    Quote Originally Posted by bebe_vega View Post
    ask them to correct it, po. they will create a new CR, is what they did to mine years ago.
    they will probably say, "sa susunod na LTO renewal po".
    Sep 2024
    Madami po ba naging requirements na kailangan kakarenew lang po kasi ng rehistro ng car last august 2024. Nung binili namin dun sa seller di namin napansin yung chasis number. Wala din po kasi kami balak ipalipat sa name namin yung CR.
    it seems to be an honest mistake.
    even the stencil boys and acid etchers, whose job it is to spot these, appear to have missed it.
    with luck, LTO will make the corrections without much ado.
    but why do you not wish to transfer ownership to your name via CR ?
    Oct 2024
    yung issue din sakin kulang ng first letter yung chasis #. Ano kaya process nito mga sir and ano po requirements. salamat po sa makakasagot
    Quote Originally Posted by gsecuya View Post
    bring the car to the lto and have them get a look-see. bring your papeles also.
    if the typo is reasonable naman, they can make it happen.
    these errors happen more often than we think.
    the act of inspecting the serial numbers is usually a difficult body position... errors are likely to happen... ... exchanging similar-looking characters... miss stenciling the first character or the last character... even wrong typing sa makinilya!
    yes, there is the omnipresent admonition, "paki-check nyo po.." , but in the heat of the excitement of owning the car... we forget our senses.
    Dec 2024
    Hello There!!
    Number 2 of posts and replies
    Hello There!!
    this original post is 14 years old.
    1. if you develop cold feet because of the potential problem, and there is really no compelling reason for you to like that car, then back away, sir.
    2. you might also ask the seller, who i assume is the name on the CR, to have lto correct it.
    3. but if the error is reasonable naman, you can probably effect the correction when transfering ownership to you. ask lto if they can do it, po. show them the discrepancy, and inquire if they will correct the error.
Chassis Number Problem
