Results 1 to 15 of 15
    Feb 2007
    Hi Guys,
    I am just wondering... Would there be any significant improvement in my car's fuel consumption if I change from carb to efi (corolla gl 90)? Any idea how much it would cost?
    TIA
    Manley
    It will not be easy nor cheap.
    There is too much to retrofit.
    I suggest you buy an EFI engine instead.
    Quote Originally Posted by manley View Post
    Hi Guys,
    TIA
    Manley
    the fuel consumption will not be that great. very minimal lang yan. if you are averaging around 10 kms/l sa GL mo, ang magiging difference lang nyan is around 1 km/l and besides as 4JG said, it would be very expensive on you. for one, the carb engine walang ECU yan, and one of the requirements of EFIs are the ECUs which regulate the flow of fuel automatically and control the burst of fuel into the engine.
    benta mo na lang oto mo ang get an injected variant.
    Changing engines to lower fuel consumption is not cost effective bro. Regular maintenance at wag masyadong todong apak sa gas pedal na lang para makatipid.
    Quote Originally Posted by 4JGtootsie View Post
    Agree
    it's not worth the hassle getting all the parts that you need just to convert your block from carb to EFI, you'lll probably end up spending more compared to buying a surplus engine.
    Dec 2007
    Hi Guys,
    TIA
    Manley
    I think a full engine swap would be the best way to do.. time for a 20 valve 4A-GE!!! hehehehe. youll get more HP but say sayonara for fuel economy! lolz!
    anywayz, on a serious note. you can swap a 4A-FE in there and be done with it. it will be reliable, powerful and much efficient than your current engine IMHO.
    aite, peace.
    Feb 2007
    KBR, Artpogi, mazingerz, 1D4LV, 4JGtootsie...
    Thanks for your inputs. Very very helpful. I'll just save some more then upgrade to a newer model with efi.
    Thanks,
    Manley
    it would not be practical to convert a carbed engine to an efi due to high cost. change engine would be the best.
    Feb 2007
    i suggest try using kia B1 carbs. you simply need an adaptor for it to fit. any machine shop can do the conversion. with it, im sure you can feel the difference.
    Jun 2006
    You might want to convert to LPG. This will give you money saving per liter of fuel. You save around P11 per liter. Check out the LPG thread for more info.
    Feb 2007
    Snowbound and userfriendly...
    Thanks for the inputs. I'll think about changing to kia carb (if I can't be able to change my car within 6-12 months... hehe). I actually heard about that before. In converting to lpg, my concern would be the availability of gas stations in places I would be going. I'm in real estate brokerage so I sometimes drive all the way to nearby provinces...
    Aug 2007
    > Just a little information about EFI and Carbs engine car
    CARBS vs. EFI
    The real question: Which is better? Well, this depends on a lot of factors. For one, what do you do with, and how do you drive your car? Obviously, if you race a vehicle professionally in which rules are involved that restrict the type of fuel delivery that can be used, you have little choice.
    The age old question has always been disputed: Which makes more power? Well, this too is a good question. Carb enthusiasts argue that carbs make more power over port injection because the fuel helps "cool" the intake manifold. If this were true, what about Throttle Body Injection? I have seen little evidence to prove that carbs out-perform port efi on identical engines and vice-versa in controlled conditions.
    Again, your choice depends on what you plan to do with your vehicle. In my opinion, carbs work great in ideal weather conditions and areas of the country which see little climate changes. Unfortunately, there are rarely 'ideal' conditions present. This leaves you to change jets and tune your carburetor to the changing weather conditions as the day goes on. On the other hand, EFI systems automatically compensate for changing conditions.
    What about cost? Well, here again, it depends on what you want to do with your vehicle. If you don't mind drivability problems when the engine is cold or the humidity is high then carbs are for you. Simply put, no carburetor can do what a feedback efi system can do compared by cost. I have never seen a carb that you didn't have to tune to offset changing conditions. These changes require carb disassembly in most cases. EFI can compensate for most any change in weather conditions. Those that cannot be automatically compensated for by the ECM can be easily reprogrammed by PC or Laptop computer in just minutes without getting your hands dirty.
    But carbs only cost $200 compared to $1000 for EFI system and programming hardware/software. Where are the savings? Well, $200 is just the initial cost of the average carb, new. Later, jet kits, gaskets, various diaphrams, and springs are required to maintain and tune carbs. Most efi systems have a highway mode operation in which fuel can be saved during periods of cruising that don't effect any other driving period. Personally, I have experienced a 4+mpg gain in fuel mileage utilizing such "built-in" features of GM EFI systems. Cost savings are self-explanitory, not to mention the time you save by simply sitting at a computer to tune your car instead of disassembling a carb.
    What kind of features does EFI offer over carbs? Well, simply put: a carburetor just sits there. A typical GM EFI computer system can be programmed in the following areas:
    Fuel Delivery based on MAP (Manifold Pressure), TP (Throttle Position), RPM, ECT (coolant temp)
    Spark Advance based on MAP, TP, RPM, ECT
    TCC Lockup characteristics based on TP, VSS (Vehicle Speed)
    Highway Mode Air/Fuel Ratio based on MAP, TP, VSS, Time
    Open Loop A/F Ratio and Power Enrichment Changes
    Closed Loop parameters
    Manifold Air Temp influence on timing and A/F ratio
    Idle Speed based on ECT
    Transmission Shift firmness and Shift Points (electronic automatics)
    Cooling Fan(s) Operation besed on ECT, VSS
    Trouble Code Parameters
    and Much, Much More....
    The Facts:
    Carbs EFI
    Winter Drivability: Poor Excellent
    Summer Drivebility: Excellent Excellent
    Skill Level Required: Average Advanced
    Initial Cost: $200+ $1000 (typical)
    Long-term cost: High Manageable
    Performance: Good Better
    Turbo-compatible: Poor Excellent
    Supercharger-compatible: Depends Excellent
    N2O-compatible: Good Good
    Emissions Friendly: Poor Excellent
    "Wow" Factor: Fair Excellent
    Reliability: Good Excellent
    Fuel Distribution: Fair Excellent (Port and Direct)
    Intake Configurations: Limited Unlimited (Port and Direct)
    Pros: 6 12
    Cons: 8 2
    speaking of engine swaps here.. pwede kaya mga 1zz-fe sa mga lumang corollas (ae92, 101 & 111)? i mean kung pwede kasi dba mas tipid sa gas yun kasi lighter ang mga lumang model ng corollas by maybe 100-200kgs.
    Dec 2007
    Quote Originally Posted by 170kphlang View Post
    IMO, the 1ZZ & 2ZZ swaps for the AE92, 101 & 111 is impractical and expensive (its the same as the K series swap on Honda's, except that the 1ZZ or 2ZZ swap has no aftermarket support and its not common *not unlike the K series swap which is pretty common, very well documented and has a huge aftermarket support.*
    anywayz, for the old skool Corollas (AE86, 92, 101 & 111) the best engine to swap is no doubt the 4A-GE 20 valve (silver or black top). but if you want an engine that is both economical and at the same time has a decent amount of power, then just swap a complete 4A-FE (2nd generation) or even a 7A-FE (or you can do the 7A-GE hybrid.. and I know how to do it! lolz!) and keep it stock.
    aite, peace.
    sell your carb car and repalce it with an EFI equip one...
Changing from carb to efi
