your milage probably went down because of the change (if at all) of the viscosity of the oil, and not the kind (mineral, semi or full syn). thicker oils will tend to put a little bit more strain on the engine causing it to be worse with the milage.
learn how to pick the correct viscosity for your car... to thick or too thin is bad for the engine.
