Results 1 to 10 of 15
- Jul 2012
- 215
December 3rd, 2013 01:50 PM #1nagpainstall ako ng central lock and alarm
normal lang ba na may kaunting rattle yung door actuator rods on uneven roads?
if not, ano solution?
walang deadening ang door panels ko
December 3rd, 2013 03:03 PM #2
Supposed to be sir wala dapat.
its either meh hindi nasikipan sa mga screws kaya yung actuator eh aalog alog,
or, kung tinitignan mo yung pag-install (or tatanggalin mo mag-isa yung sidings),
meh mga foam na nakabilot on some parts, those are there to prevent magcreate ng sound
pag tumamatama sya somewhere dun sa loob, pwedeng hindi nila nalagay sa saktong lugar pagbalik.
- Jul 2012
- 215
December 3rd, 2013 03:19 PM #3
It's not the actuator but the rods that are rattling. di talaga fixed yung rods like in all actuators di ba? talagang may konting provision for movement
(the long thin rod in the pic)
and I can't see any way how to fasten it up without affecting the actuator's moving left and right (horizontal ang placement ng actuator rods dahil horizontal ang lock ko
any solution to this problem?
December 3rd, 2013 03:38 PM #4
Yes, fixed ang actuators,
yung mga rods yung tinutukoy ko dun sa mga parts na meh mga balot na foam,
palagyan or lagyan mo nalang ng foam okei na yan. just enough para hindi lang tumunog,
pag makapal, baka mahirapan naman yung actuator mo paandarin yung rods.
- Jul 2012
- 215
December 3rd, 2013 03:41 PM #5
December 3rd, 2013 03:57 PM #6
Pag nakatanggal yung sidings, you would usually see foam nakastick to the door itself, or nakabilot sa rod.
Ordinary foam will do sir, mapinpoint mo lang kung saan sakto nagiingay, then lapatan mo lang ng foam
kung saan sya bumabangga stick it with a thin double side tape, problem solved na.
- Jan 2008
- 4,726
December 3rd, 2013 04:02 PM #7bili ka ng AEROTAPE yung mga ginagamit na insulation ng mga nag iinstall ng aircon.. foam tape yun. pwede mo balutan ng konti yung joint ng rod at actuator baka yun ang nag vibrate... pwede mo din lagyan yung in between ng actuator at door frame.. tapos balutan mo din yung wires, connectors
- Jul 2012
- 215
December 3rd, 2013 04:15 PM #8
December 3rd, 2013 07:15 PM #9
If the rattle is coming from the rods, you can just apply some automotive grease at the rod ends to stop them feom rattling im their sockets.
Are you sure the rattle is coming from the rods? It might be from loose wiring in the door that was not returned properly after they reassembled your doors.
Sent from my Nokia 5110 using Tsikot app.
- Jul 2012
- 215
December 3rd, 2013 10:07 PM #10
siya nga. i tweeted the mmda and they replied it's suspended nga.
Traffic!
