Results 1 to 10 of 11
June 27th, 2007 08:52 PM #1
Honda Civic ESi
Continuous CEL - diagnosed already still continuous CEL lit.
May spark sa 4 na hi-ten, ayos ang fuel pump (nirekta ko sa battery), palit main relay, may redondo ayaw lang tumuloy. Baka daw ECU na may problem. Kung ECU nga, pano nasira? Katagalan? Faulty wiring/ground? Kung faulty wiring, san? Paano?
Baka meron malapit sakin na pwede ko dalin yung ECU ko sa EG nyo para ma confirm ko kung sira talaga ECU ko. Help.
Tnx.
June 27th, 2007 10:50 PM #2
Where you able to retrieve the trouble code manually?
if yes,what numeric value did it reveal?
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 27th, 2007 11:27 PM #3you have to know what the cel code is before we can be of any help. if you want have it towed to the shop and we'll help you resolve it.
June 28th, 2007 12:18 PM #4
i already jumped the diagnostic socket. unfortuantely i still get continuos CEL.
*speedyfix - meron kayong tow service?
June 28th, 2007 08:33 PM #6
yes i know. it doesnt say anything except for continuous CEL.
here were the steps i did:
1. key off
2. jump the diagnose socket (sure ball contact)
3. key ON
result:
continuous CEL (with or w/o the jumper wire)
June 29th, 2007 08:05 AM #7
Walang blinking?
Talagang diagnostic tool ang katapat niyan. Goodluck!Last edited by 4JGtootsie; June 29th, 2007 at 08:32 AM.
June 29th, 2007 06:25 PM #9
Sabi sa notes na kung continous ang MIL ibig sabihin ay the back up is taking over. Another way to check the malfunction is for you to connect a working ECU which is what you suggested at the beginning of your thread.
Dont you have friends who has the same ride as yours that you can borrow from.
Sa Meralco at Samson meron kaming ginagamit pero ewan ko kung pahihiram.
- Nov 2003
- 3,849
July 3rd, 2007 11:09 PM #10assuming you're doing it correctly then it's probably a burnt box. pero i highly doubt it since medyo matibay naman box ng honda. so either have it towed or re-do the jumper.
of course! the former was more enlightening than reading the Holy Book. mom loved the Ten...
Traffic!
